FRPP Hotrod cam owners, I need help......
Old 08-17-2009, 10:30 AM
one.wicked.stang
one.wicked.stang's Avatar
Default FRPP Hotrod cam owners, I need help......
I have a 2006 Mustang GT (Automatic) that I had the FRPP Hotrod Cam installed on. When the car is at a low idle sitting still (parked) it runs fine, it also runs fine at freeway speeds. However, in stop and go traffic conditions or low rpm cruising in town light to light driving the O/D off light will start flashing and the car starts driving badly (wont shift, higher revs between shifts, stuff like that). If I pull over and shut the car down then restart it and get out of the conditions mentioned it runs great. Anyone else have a similar problem or heard of this. With the stock cams in I NEVER had this problem. The tunes are from Bamachips, the tune the day of the install was not modified for the cams and it had this problem, the tune for the cams has this problem also. Could it still be a tune issue or something else?
one.wicked.stang is offline
Old 08-17-2009, 11:38 AM
KcMstang
KcMstang's Avatar
I would contact Doug at Bamachips for his advice. To me it sounds like something in the tune needs to be adjusted like the idle. Have you tried any adjustments yourself? Might to to plug in the tuner and try raising the idle and see what happens.
KcMstang is offline
Old 08-17-2009, 01:09 PM
RainsFather
RainsFather's Avatar
Crazy question- are you running the a/c when this is happening? I know installing my HR cams made running my a/c in stop and go traffic make my car run like ****.
RainsFather is offline
Old 08-17-2009, 06:09 PM
SirKnightTG
SirKnightTG's Avatar
Ah man I don't want to hear this! LOL! I guess the Comp Cams Thumprs would be the same...
SirKnightTG is offline
Old 08-17-2009, 07:10 PM
hammeron
hammeron's Avatar
+1 RainsFather, i know exactly what you are
referring to.
i generally turn the ac off when in stop and go
traffic and turn it on when longer stretches
are available. it's not that it runs terribly, it's
just that we can tell some of the low end torque
is missing in action....
it's the price we pay to play
hammeron is offline
Old 08-17-2009, 07:53 PM
SirKnightTG
Well down here in Tejas turning off the A/C in the summer is just not going to happen.
Old 08-17-2009, 08:59 PM
jgf07
jgf07's Avatar
don't worry about it, mine does it sometimes. you need to adjust the idle to 800 rpms will help out with this. but it is no cure,i think it just freaks the auto tranny out because of the lopey idle. mine does the same thing yours does. 11,000 miles with hot rod cams no problems. except the occasional o/d light flashing. nature of the beast..
jgf07 is offline
Old 08-17-2009, 10:01 PM
hammeron
hammeron's Avatar
we shall see
hammeron is offline
Old 08-17-2009, 10:03 PM
hammeron
hammeron's Avatar
very nice to hear jgf07, i may have 1500 miles
so far and also no problems
hammeron is offline
Old 08-19-2009, 06:29 AM
one.wicked.stang
I was emailed a new tune from Matt at Bamachips yesterday evening that was written from scratch off of a base file. I installed tune and drove the car down the street to my buddys house and around the hood. Light never came on, it usually (90% of the time) comes on. The true test will be on the way home from work today because I'll be in stop and go traffic where the O/D off light would always (100%) start flashing. I'll keep everyone updated...........
Quick Reply: FRPP Hotrod cam owners, I need help......
