good one...I almost moved this to useless!....or O.T.....anyway post everything back here when its done...we want vids, pics, and dyno sheet....oh a/f ratio's and max timing if possible! thanks
Just got home, the first pull with the Lethal tune was 473 HP at about 440 lbs of torque. It was a little lean, so he had to richen it up a little wich got me a 465.4 with the same torque. The dood said, that the ten table are so different, that he would have to build the tune from the ground up, and at least 500 HP safe is possible. To do that I'm going to have to leave it all day. I was impressed!
I know I am splitting hairs but I merged the 2 threads you made....awesome results and do you know what the A/F ratio was? or the what the timing (max) is set at? fuel trims?
