RPM's keep dropping
Old Oct 21, 2009 | 02:29 PM
aquajr's Avatar
aquajr
Default RPM's keep dropping
The last two weeks I've been noticing something odd.
When I start up the car and drive off, it starts and goes normally. Then I roll up to a light and stop. The rpms drop all the way down to 500 then up to 1000 then down again, and it finally settles in at 750 like normal. This happens a couple times then stops once I've been driving for a while.
It's a worse if I have the air conditioning on. It'll happen the same way but won't stop.
The only change to my car recently has been a new battery about a month ago.
Old Oct 21, 2009 | 05:46 PM
chronos's Avatar
chronos
It could be the A/C kicking on and off, it could be the PCM making adjustments due to a poor signal from the battery or alternator. Everything is controlled by the PCM, something is obviously bothering it. Injectors could also be a little clogged causing variations in fuel mixture. When was the last time you changed your fuel filter?
Old Oct 21, 2009 | 08:16 PM
Nuke's Avatar
Nuke
Originally Posted by chronos
...Injectors could also be a little clogged causing variations in fuel mixture. When was the last time you changed your fuel filter?
Or the last time you ran a tank of gas with a fuel system cleaner?
If you have your heating system on DEFROST, it also runs the compressor so that would act like the A/C was on.
Old Oct 21, 2009 | 09:23 PM
Lifter583's Avatar
Lifter583
Clean the MAF sensor and throttle body
Old Oct 21, 2009 | 09:34 PM
aquajr's Avatar
aquajr
The fuel filter was changed 2 months ago - its been about 3k miles. I haven't used a fuel system cleaner.
Thanks for the quick responses guys. I'll give this stuff a shot.
If anybody got more idears keep em comin.
CS2007
Jun 25, 2019 09:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
