Aluminum drive shaft
Old 12-06-2009, 09:56 AM
rpietro
rpietro's Avatar
Default Aluminum drive shaft
Hello Everybody,
I'm thinking of having my stock steel drive shaft changed for an alunimum drive shaft. Has anybody done this and what can you tell me about it...Is it worth the cost and touble or am I wasting good money?
rpietro is offline
Old 12-06-2009, 11:36 AM
hammeron
hammeron's Avatar
hello rpietro,
if you are trying to free up every possible
horsepower and/or, are wanting to beef
up the driveline because you plan to make
lots of power in the future, then it could
be worth the cost and trouble.
hammeron is offline
Old 12-06-2009, 12:21 PM
Casey4s
Casey4s's Avatar
I put a SpyderShaft in my 05 GT Automatic two years ago and it was a good investment IMHO. It takes all the slop and clunking out of the drive line and shaved about .2 off of my ET. There are a lot of brands available out there to choose from so my only advice is choosing a DS is to get one engineered to be an exact fit for your car and not one that needs an adapter of some kind to install it in your car.
Casey4s is offline
Old 12-06-2009, 01:43 PM
rpietro
rpietro's Avatar
Thanks Hammeron. That is exactly what my ultimate goal is. Good advice. Thanks again
rpietro is offline
Old 12-06-2009, 01:48 PM
rpietro
rpietro's Avatar
Thanks Casey4s. I wanted to hear from someone that actually did the mod.
rpietro is offline
Old 12-06-2009, 06:19 PM
6+6 Stang
6+6 Stang's Avatar
heres a great link to install one, talk to one of the brothers at shaftmasters, they balance then rotate 180, balance again, any issues they stand behind, plus stock DS weighs about 40 ibs aluminum weighs about 16 lbs
https://mustangforums.com/forum/2005...ll-w-pics.html
6+6 Stang is offline
Old 12-06-2009, 07:52 PM
W1ldcat
W1ldcat's Avatar
Much smoother with no clunk in my auto. No times to back it up, but feels a little faster. You lose a LOT of weight.
W1ldcat is offline
Old 12-07-2009, 09:55 PM
Lifter583
Lifter583's Avatar
I run a Dynotech 3.5" runs perfect!
Lifter583 is offline
Old 12-08-2009, 12:49 PM
onederful100
onederful100's Avatar
i have a spydershaft, and its great, no problems with it.
but i think if you just do bolt ons and dont go the track, it's not worth it.
like Hammer said, if you plan to do a lot, then it is worth it.
onederful100 is offline
Old 12-08-2009, 01:26 PM
moosestang
moosestang's Avatar
Well the stock shaft does an outstanding job at reducing engine/transmission vibrations. You may have a slight vibration that you can't feel with the stock shaft, but will be quite noticeable with an aftermarket shaft.
It does make your foot feel more connected to the rear wheels.
moosestang is offline
Quick Reply: Aluminum drive shaft
