2005 mustang GT *compression test results* ~give your thoughts~
well i bought this car 3 months ago, and it had 68k on it and now it has 73k on it......
i figured i would do a compression check to make sure all is good..i had to track down a cornwell tool truck to get the 14mm female to 16mm male adapter for the triton 3v engine....9 bucks.....snap on wanted 100.....ahah....
well here are the results using a actron compression tester..(the kind that the hose slips in like a air compressor hose)
using the diagram right below, to match each cylinder to my results:
results in psi, turned key timed 5 seconds, did each cylinder 3 times...let me know what you think...
1. 216
2. 219
3. 220
4. 221
5. 217
6. 214
7. 216
8. 220
EDIT:also for those who are scared to remove spark plugs on the 3v, i have done it 4 times, no problem....just loosen a 1/8 of a turn, spray liquid wrench 2 quick sprays, let sit for 20 mins, work them out very slowly.....
then its very important to take a lint free rag and wipe down in the whole or spray carb cleaner, because the smooth portion of the plug is what gets stuck and it does this because of buildup....when you put your new plugs in drive around a few days and remove them to make sure there is no more buildup on the sides, if there is wipe and reinstall and check again a week or so later....if not your good....just remove them every 4k or so to clean and make sure all is good...
its much better than getting one stuck in there....
1. 216
2. 219
3. 220
4. 221
5. 217
6. 214
7. 216
8. 220
i bought the compression tester at advance auto, but you have to get a 16mm adapter to fit the thread of the 3v engine....you can get the compression tester adapter fitting at any cornwell tool truck for 9 dollars...
