Autolite HT1.... FAILED....
Old Jan 2, 2010 | 09:29 PM
javina80's Avatar
javina80
Originally Posted by Torch Red GT
Okay sounds good i should probably change them soon since im at 40k miles, they sell these at autozone right?
I am sure they do, but they are not cheap with Auto Zone, I would go on rockauto.com, or check with an independent parts house close to you. FRPP also makes a set of one piece plugs, let me get you the part number in a bit....
Old Jan 2, 2010 | 10:16 PM
Simon1's Avatar
Simon1
Are the HT1's the correct plugs for an almost stock car? I was just looking at the detonation marks on the two left plugs. Left one is horrible, middle one not too bad.
I've just never seen such bad detonation on any plugs pulled out our cars.
You couldn't hear anythig wrong while driving?
I would put a scope down in that cylinder to see what it looks like. Actually, I probably wouldn't. I wouldn't want to know.
Old Jan 3, 2010 | 11:42 AM
Goldenpony's Avatar
Goldenpony
FRPP also makes a set of one piece plugs, let me get you the part number in a bit....[/QUOTE]
Are you sure about this? The only 1 piece plugs I've ever seen are the Brisk or the Champions. NGK is working on one, but they're not ready yet, they recommend using the Champions until theirs are ready.
Old Jan 3, 2010 | 12:16 PM
javina80's Avatar
javina80
I am wrong, they are for the 08-up head design that take the 12mm thread.... sorry fellas
Old Jan 3, 2010 | 05:07 PM
SirKnightTG's Avatar
SirKnightTG
I'm going to be pulling my HT1s out for some Champion one piece probably in a few months. I sure wish I would have researched this better before buying HT1.
I used anti-seize so hopefully there will be no problem getting them out. I don't want a repeat of when the stock plugs were pulled (but I had 50K on them and only like 13K at the most on these HT1). Two broke and it took all day to finally get them out.
Old Jan 3, 2010 | 05:25 PM
1badpony's Avatar
1badpony
Anyone have a link to good info how to gap those style plugs without buying a special tool?
Old Jan 3, 2010 | 06:43 PM
moosestang's Avatar
moosestang
A socket and a C-clamp should do the trick.
You must have heard pinging for the plug to be that damaged.
Old Jan 3, 2010 | 07:42 PM
1badpony's Avatar
1badpony
And feeler guages? any diagram of someone doing this?
Old Jan 3, 2010 | 10:22 PM
Simon1's Avatar
Simon1
[QUOTE=moosestang;6728286]A socket and a C-clamp should do the trick.
You must have heard pinging for the plug to be that damaged.[/QUOTE]
No one seemed to notice my post above. Me and you are on the same page.
Almost seems like part of the story is being left out or the OP is totally oblivious to noises coming from his car.
Old Jan 3, 2010 | 10:24 PM
Goldenpony's Avatar
Goldenpony
With only that many miles and using anti-seize, you shouldn't have any problems getting those HTs out.
