Autolite HT1.... FAILED....
note that when choosing between the champions and the brisks that brisk is currently the only company making a colder heat range "one piece" plug than stock but not many people have had them last longer than 6 months. So for a N/A setup go champions, for a FI setup go either Autolite HT0 and risk the two piece design and annoying way to gap them or Brisk and risk them not lasting.
something else is going wrong with this than just the plugs being trash.
I know many many guys running HT0's and HT1's in their 4.6 and 5.4 motors. Not a single one has issues.
On the flip side, damn near everybody I know running those Champions has nothing but issues. Especially with them fouling and the gap being hard to set properly.
you sure your motor isn't damaged? you had something seriously wrong going on there. Those plugs are way to dark and covered with unburnt fuel. How long were you driving with this condition?
I noticed issues about a week ago... NO I am not oblivious to what pinging/detonation is, and NO I am not leaving anything out of my story, I'm just sharing an issue I have unfortunately experienced..... Only present issues were a misfire and gas mileage went to crap. I have gotten in contact with the tuner I got my tunes from, and I think I got a bad tune.... There is no engine damage, compression hits good, and valve events are dead on..... No loss of pressure either with a leak down test. I am very fortunate so to say that the engine did not suffer any damage. It is as if that plug just burned up. I don't beat the crap out of my car, I drive it close to 100 miles a day. Sometimes I do get on it and do listen. I am not one to throw around what I know, or what I have done on cars, or where I ahve worked on them at. All I know is somethin happened here and sharing what I found..... Oh, and on the pic, the only one used is the Autolite on the left, the middle Motorcraft is a new one out of the box. I just used at as an example to what the HT1 was supposed to look like. I am pretty sure my tune was makin it run super lean though, no bueno....
nothing personal man...it's just not often you see stuff like that. and usually people leave the important stuff out of their story since it seems to never be their fault.
side note: were you using the proper octane gas for the tune? or perhaps got bad gas? I had a tune for 91 octane in my F-150 (Supercharged) with a 30 gallon tank of 87 & 93 octane mixed...the truck did not like that mixture.
I agree. and then once the electrode was damaged, the unburnt fuel caked the plug
You're reading different posts than I do. I see very few issues with Champion 1 piece plugs. Most reports I see, people are very happy with them. I've got over 25K miles on a set of Champions and not one single problem. I recently had a leak down compression test run. I asked the tech how the plugs looked, he said they looked great and he just put them right back in. I can't imagine why you say they're hard to gap, it's a standard design that has been around forever, quite easy to set the gap. Just my $.02 worth.
They don't make one for the 3V engine. Also, no plug "makes" HP. Your engine makes the HP, all the plug does is light the fire.
