brake bleeding
Old Jan 19, 2010 | 10:12 AM
schapman's Avatar
schapman
Default brake bleeding
Can we bleed our brakes normally? or do we have to do something with the antilock brakes and traction control unit?
Old Jan 19, 2010 | 06:53 PM
Goldenpony's Avatar
Goldenpony
As I understand it, as long as there is no air in the ABS unit, you bleed the brakes normally. It is very important not to let the master cylinder go dry and get a big gulp of air, then you have a problem. I have read if you do get air into the ABS unit, you have to take it to the dealer to be bled.
I bled the brakes on my '06 GT without incident. Just start with rt. rear, lt. rear, rt. front and lt. front. I installed some Speed Bleeder screws - best money I ever spent. Best of luck.
Old Jan 20, 2010 | 09:05 AM
Diabolical!'s Avatar
Diabolical!
I use the old 20 oz. bottle and clear tubing method. Just make sure you keep the master cylinder topped off during the process and bleed as normal.
Old Jan 20, 2010 | 11:06 AM
157dB's Avatar
157dB
Cut & Paste Expert
Fords Way o da hi way
Someones life is depending on YOUR brakes...
Old Sep 3, 2010 | 01:23 PM
Bmr4life's Avatar
Bmr4life
Thanks, that's simple enough for my wife to help with. How much fluid do I need to flush it all out? I bought one 32 ounce bottle of the Valvoline Dot3/4 from Autozone.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
