Need cam evals
Need cam evals
I got my heads back from the porters, now I need to buy cams so I can install both at the same time, what I would like to know is, what cams you have and how the cams effected the drivablity of the car, did you loose low end? did you gain mid and top but lost lots of low end grunt? give me info so I can make the correct choice the first time... Thx guys for the help
I'm running the comp xfi stage II NSR cams with ported heads. I'm not getting the most of ported heads with these cams. They just aren't aggressive enough. However, the big heads definately DECREASE the velocity of the intake and I lost around 50ft/lbs of torque down low. Despite the low end torque loss, the only place I feel I lost any sort of drivability was between 2000-2300. There's just a big dead spot there. Above ~3000 the car just screams.
I hope you plan on going big with the motor, or putting F/I on the car with the heads, because I'm afraid you may be a little dissappointed with the results given the cost.
Bullitt, not really looking for a recommendation, but at the same time I don't want cams that will loose too much lowend torque, my heads started off as used MMR stage 2, more porting was done around the chamber and pockets, new 1mm over Ferara valves, car is used as a daily driver, and I would like the car to keep some forum of manners, looking at everything from Fords cams to AMS N grinds to Comp 127300-127500 grinds,, speak up and tell me how your car behaves on the street. I'm hoping for 350whp after these mods w/long tubes, and later I can go FI running low boost and max out the stock block, but I'm not looking for FI cam specs right now I'm asking how your car drives with your aftermarket cams Thanks again.
No matter what cam you go with, for a DD, I think you're going to have a more noticable low end torque loss with the ported heads. The heads just kill the intake velocity. I think that if you leave the IMRC plates alone you won't give up nearly as much low end, but you will make a peak hp sacrifice for it. Long tubes will likely get you to 350whp, but won't help the low end at all, especially if you go sans cats.
I just drive around the flat spot in my powerband. I thought about doing gears, but decided to try to drive around it first. I try not to cruise in any gear below ~2500rpm. The pro is that the car is ultra responsive and quick to accellerate. The con is that it feels pretty aggressive for simple around town driving.
I thought my cams were on the tame side of things because they are an NSR cam. I purchased the 127200 cams on the recommendation of my tuner before I had made the decision to do the heads, otherwise I would have gone with a more aggressive SPR cam. As far as how it sounds, you really have to listen close to even know that it's a cammed car. If you are looking for that real lopey idle, the XFI cams aren't going to do it for you, but I have doubts that the Hot Rods and Thumpers will get you to 350whp without F/I. Long tubes may get you close, but it will be a push as long as you are running cats.
