Next step HP gain help???
Got a 05 GT convertible, 4.6, 3 valve, 5 speed.
So far we installed Steeda UDP's, Steeda CAI, Magnaflow high flow cats and a SCT custom tune. + a Hurst competition plus short throw shifter.
I'm looking for the next step and bang for the buck for HP increase.
Do I get headers, delete plates, bigger throttle body, cams or what.
Not quite ready for the high priced supercharge YET.
What do the experts recommend?
Any and all suggestions would be appreciated.
Thanks in advance
falconsprint
Thanks in advance
falconsprint
It really depends on what you're looking for. No reason for the throttle body unless you've got cams, headers and spin the motor over 6500rpms. The delete plates to me are more of a safety mod and also help out when you have headers and cams since it will let them flow better.
I would get a nice 1-piece aluminum driveshaft first, then long tubes, then cams & delete plates together if I were to pick an order.
Cam's with LT's would probably be the best bang. Afternarket TB's are useless unless you're HEAVILY modded so nix the TB thought. UDP's, electric waterpump, aluminum DS... Just a few thoughts off the top of my head.
Thanks in advance
falconsprint
Thanks in advance
falconsprint
if you want the best "bang" get gears. while there is no hp increase it will "feel" like more hp than any other "bolt on." drive shaft would be nice, headers if you can go lt if not i wouldn't waste my money on shorties. don't forget after you have more of these go fast mods you will want something to hold it there, such as lcas and other suspension upgrades
