Car feels like it is skipping a beat???
While driving the car under acceleration everything feels fine, however, when cruising at a constant speed (45mph) it feels like the engine skips a beat, like a very faint jerk?
I think if you are a passenger, you don't notice it, but when you are connected to your Mustang as much as we are, we notice every little change!
Is this something simple or an underlying problem?
I'm going to clean the air filter today and also check the air sensor on the CAI..... is there anything else I can do? Could it be the spark plugs?
Thanks all
Thanks all
I had some little hiccups in the feel of the motor. I went from the preset gap of .032" (I think that's what they were) down to .027" and it seems to be running smoother. I had little hiccups in very low load at lower rpms when the car was cold. like in the morning as I drove out of my neighborhood on the way to work. tonight on my test drive it felt better but the real test will be tomorrow morning when it's cold.
the gap is very important so if you've got the right plugs in already or if you're going to order them make sure you're running the correct plug gap on them or you can get some issues too.
for what's it's worth I closed the plug gap on my one heat range colder brisk plugs and that's fixed 90% of the hiccups I was feeling. I closed them down to .027" and that's working pretty well even this morning on a cold motor. part throttle low load was much smoother as I drove out of my neighborhood.
