Urget....squeaking problem
I would not worry about a bushing sqeaking. However, I would worry about it if it were a clunking sound. Bushings, even rubber ones, will occasionally make noise. It's just a fact of life- and as cars get quieter, people can pinpoint the slightest of sounds.
In regards to the clutch pedal: if it's the pedal itself making noise on the pedal lever, it's also not a big deal. There should be a plastic bushing- if I recall correctly, with some grease on it. If everything appears intact, then just take some normal white grease, aka white lithium grease, and lube up the pivot.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
