Urget....squeaking problem
Old May 25, 2010 | 06:06 PM
stealth32's Avatar
stealth32
Exclamation squeaking problem
hey guys i got 2 problems and i need to know if if i should take this in for service and them check it or if i can do this myself. First off every time i press the clutch is squeaks.Not loud but its noticeable. Second; after i put my new rims on ( 19's ) every time i go over a bump it squeaks from the rear on the passenger side. Its fine when i drive but if i go over some holes on the road or speed bumps i hear a squeak. What could be causing this. Thanks
Old May 25, 2010 | 06:11 PM
howarmat's Avatar
howarmat
s197 Junkie
you need to remove the mice that are squeaking ....
Old May 25, 2010 | 06:20 PM
stealth32's Avatar
stealth32
Yea I tried that already any other suggestion haha
Old May 25, 2010 | 06:30 PM
alkemist's Avatar
alkemist
Maybe it's the Urget that's squeaking.
Old May 25, 2010 | 06:34 PM
stealth32's Avatar
stealth32
Typed this off my phone urget o sry... urgent that better all seriousness can you guys help me out or what
Old May 25, 2010 | 06:43 PM
cidsamuth's Avatar
cidsamuth
You'll have to be more specific -- is the clutch pedal squeaking, or is the tranny squeaking when you push the clutch in?
With the wheel, just pull it off and make sure you didn't knock anything loose. If it has center caps, check those.
Old May 25, 2010 | 07:00 PM
stealth32's Avatar
stealth32
Its deff the clutch pedal sry . And when I take the wheels off what should I look for that might be loose does the clutch pedal need to be greased or something I don't know just asking thanks alot
Old May 25, 2010 | 07:25 PM
socalwrench's Avatar
socalwrench
Not sure if you need to take the wheel off, but just check to make sure all the suspension attachment points are secure, and that the dampers and springs aren't loose. The noise could just be a bushing.
However, I would make sure that the wheels are completely centered and flat against the mounting surfaces. I mean, noises are fairly difficult to diagnose with words. In a rare instance, you could have overtightened one of the lugs and it slightly warped the rotor.
Old May 25, 2010 | 07:31 PM
SpartaPerformance's Avatar
SpartaPerformance
The squeaking in the suspension could be a result of the rims, if the wheel is heavier then stock changes the unsprung weight, it could be just a bushing.
Old May 25, 2010 | 07:47 PM
stealth32's Avatar
stealth32
Should I be worried if it is in fact bushing. I will take off the back rims trmw and let you guys know. Thanks again guys for the wheel noise problem. What about the cluth pedal noise then
