2007 overheating
Old May 29, 2010 | 11:38 AM
Simon1's Avatar
Simon1
Originally Posted by wildazme
ok when i say overheating, i mean im driving the car for awhile and the temperature needle climes all the way to the red danger mark on the gauge. I put the heat on full blast to get it to fall slightly under the red mark until i can get the car off the road. when i open the hood the fans are not on. there is no coolant leaking, my hoses are fine. The list of mods are in my signature and i have been driving with those mods a few months and everything was fine. the last thing i had done on the car was an oil change. also when the car gets that hot my overflow tank fills completely up.
So the fan is not working which means either:
1. The fan motor is out. After confirming the harness is good, I would directly connect it to the battery and see if the fan comes on. Use a fuse jumper.
2. The harness is not plugged in or there is problem with the lead to the fuse box. This may include a damaged wire. I would trace the harness start to finsih to illiminate this.
3. The relay is out. An electrical tester would tell you this. You should manually jump the fan with a fuse jumper and see if the fans comes on.
4. The tune needs to be adjusted. You will be able to see this in your tuner. Plug it in, go to custom tune, and go to fan temps. They should be set at somewhere between 180 and 160, depends on what kind of thermostat you have.
Old May 29, 2010 | 11:51 AM
BruceH's Avatar
BruceH
More than likely the tune is set for some high number associated with old school cars. Keep the low speed and high speed at least 10 degrees apart. For starters I'd put the low around 160 just to see if it's kicking on. You can also datalog temps with your tuner and see what the computer thinks they are.
Old May 29, 2010 | 03:41 PM
wildazme's Avatar
wildazme
i know there is one fan if i typed fans it was a typo. the fan comes on when you use a fuse jumper so the fan motors are working. the one plug that goes into the fan is connected. I replaced both relays for the hell of it so i know they are good. the temp settings that are in the tune are the ones that were supplied by diablosport as part of the all inclusive kit that comes as a complete package with the vortech, and once again i was using this tune for months with no problems.
Old May 29, 2010 | 04:39 PM
157dB's Avatar
157dB
Cut & Paste Expert
i know there is one fan if i typed fans it was a typo. the fans come on when you use a fuse jumper so the fan motors are working. the one plug that goes into the fan is connected. I replaced both relays for the hell of it so i know they are good. the temp settings that are in the tune are the ones that were supplied by diablosport as part of the all inclusive kit that comes as a complete package with the vortech, and once again i was using this tune for months with no problems.
Air Bubble.
Burp the system.
Or a popped head gasket is introducing air into the system.
Do a compression check on all 8 and get back to us....
Old May 29, 2010 | 07:39 PM
White05GT's Avatar
White05GT
Maybe your thermostat needs replacing.
Old May 30, 2010 | 02:23 AM
Simon1's Avatar
Simon1
If there is a code coming on I would guess it would be your cylinder head temperature sensor. Do a scan with your diablo and see what it says. I have an extra sensor in my garage if you need one.
Reading thru the manual I would lean towards having a sensor going whacky. I'm surprised the machanic didn't notice it earlier.
Did you take it to a dealer or just some mechanic?
BOB ROME
Jul 26, 2023 01:54 PM
CS2007
Jun 25, 2019 09:45 PM
piotrek53
Oct 13, 2015 06:54 PM
Seanam
Oct 4, 2015 10:15 AM
MusicCity615
Sep 12, 2015 07:05 AM
