LT Headers question
Old Jun 9, 2010 | 10:24 PM
marlinmon07's Avatar
marlinmon07
Default LT Headers question
Do you need to install any type of sealant on the header gaskets or just stick the gaskets right on? I'm using the BBK replacement header gaskets btw
Old Jun 10, 2010 | 08:04 AM
dysan's Avatar
dysan
I would suggest putting a light coating of the high temp copper rtv on both sides of the gaskets. I meant to do that when I installed my kooks and I completely forgot. I had to go back and re-tighten my bolts down to stop a slight leak due to it.
Old Jun 10, 2010 | 12:46 PM
SpartaPerformance's Avatar
SpartaPerformance
As far as I know none of the exhaust header manufacturers require or recommend and gasket sealer. Just tighten in sequence which is top back bolt then bottom back bolt, going towards the front of car top to bottom and tighten to 18ft-lbs
Old Jun 10, 2010 | 04:35 PM
808muscle's Avatar
808muscle
No sealant for me, just percy gaskets.
Old Jun 11, 2010 | 05:39 PM
shanec's Avatar
shanec
I re-used stock gaskets, no sealant, and I have no leaks. The stockers didn't have sealant either.
Old Jun 13, 2010 | 07:46 PM
drbobvs's Avatar
drbobvs
+1, use stock gaskets (get a new pair from the dealer if you like) They never leak!
Luke9222
Oct 22, 2015 11:55 PM
firecoyote
Sep 27, 2015 02:37 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
BrantleyS550
Sep 14, 2015 04:18 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
