dynoed today .......are these numbers right?
Did Brenspeed account for the elevation in CO in their tune? Did the dyno tech record your AFR? Did he data log at all while on the dyno? If he did, send the datalog to Brenspeed and have them modify the tune. They might even be able to modify your tune off of the dyno graph as long as it displays AFR.
The thin air up here is definately not as friendly to N/A mods as it is F/I, but I would expect to be making better numbers with what you have.
id go to a dynojet if you want numbers. if you want to see how the tune is, a dyno dynamic is great. just dyno dynamic leaves more room for user error (virtually every dynojet will read very close to one another depending on temp, humidity, etc) plus it reads lower.
i was told that dynojets are more ideal for a mustang so im trying to locate one ...hopefully there is someone else close by where im at!
