Just bought an 07
Old Aug 9, 2010 | 07:52 PM
99gtstang's Avatar
99gtstang
Old Aug 9, 2010 | 07:55 PM
99gtstang's Avatar
99gtstang
Originally Posted by mapitts
+1 on the throttle body or throttle body spacer. I read somewhere that the stock throttle body can handle over 1000 cfm. Don't know if it is true though.
Thats the route i will take no TB for now thanks
Old Aug 9, 2010 | 07:58 PM
99gtstang's Avatar
99gtstang
Originally Posted by Pony123
for a dealer to VOID your warranty they most prove that the modification you did is the cause of the issue your having
Example: my radio doesnt work. They cant void that because you have and intake or supercharger. but they can void it if you have a aftermarket sound system
Makes sense, Do you see where LT'S and full exahust could potentially mess anything up on the motor side?
Old Aug 10, 2010 | 09:40 AM
157dB's Avatar
157dB
Cut & Paste Expert
Warranties are for women.
You play hell getting warranty work done.
Put your extended warranty $$ into the bank for a rainy day.
Its a lot easier to access that way.
Forget the warranty voiding and have some modding fun.
You only live once.
Old Aug 10, 2010 | 12:23 PM
Nuke's Avatar
Nuke
Read peoples sigs. Most are running Brenspeed or AM tunes (BAMA is defunct but incorporated with AM).
Old Aug 10, 2010 | 07:19 PM
99gtstang's Avatar
99gtstang
You only live once.
guess im a woman hahahah
no extra money or monthly cost. They tell me factoyr 5 yr 60K and because it was a certified pre owned for "free" comes with 6 yr 100K limited powertrain warranty.
Old Aug 10, 2010 | 11:13 PM
808muscle's Avatar
808muscle
Emblem on 3d eleanor grill is a bolt on optional piece. I did not install either.
Old Aug 12, 2010 | 10:57 AM
ElDude's Avatar
ElDude
IIRC if you have to bring the car in fro warranty work and you have a tune all you have to do is reload the stock tune and then unplug the battery for 20-30 minutes. When the techs ask why the battery was reset just tell em you had to clear the open gas cap message (I think that's the excuse to use).
First mod I would do is aftermarket LCA's since the stock ones are made out of jello and wheel hop like crazy
Old Aug 12, 2010 | 09:52 PM
nickb2236's Avatar
nickb2236
What they said about the warranty.
I have the 2nd link for the eleanor grille. Install was easy and look really good. Only issue I had was the relocation of the fog lights made me modify the metal support behind the grille because the fog light wiring would not fit. I would imagine the 1st grille would not have that problem since it's farther apart but I wanted the chrome trim around the fogs and outer edge.
Old Aug 13, 2010 | 07:55 PM
99gtstang's Avatar
99gtstang
How about the UCA? I replaced both on last one they made a difference. Luckily i talked to the shop manager at ford. He was cool he has a twin turbo GT. He said just put stock tune back in and leave alone. Even if CEL is on for no cats he will look around that if problems lies somewhere else....... As much as i like the lowered look... man this vs. last car C springs cut front half coil. I think i am going to leave stock height
