New Mustang Owner needs direction!!
Old 09-02-2010, 01:49 PM
rookieassstangrookie
rookieassstangrookie's Avatar
Ok, good info.
The JLT sounds like a good value, I was eyeballing the steeda high velocity cold air kit, http://www.steeda.com/PR/Products/555-3120/555-3120.htm, it claims 30 rw hp, but I am sure in practice it falls short, and the JLT is about 100 buck cheaper which I wont cry about.
I see, so you can get some power out of the exhaust system, but of course nothing from swapping out your mufflers. Makes sense.
I see how 4..1s could be annoying with a s/c on a stick. Is there a performance disadvantage to running through your gears quickly (in general of course) or is it simply annoying to shift all the time. I dont really have to worry about shifting I suppose.
rookieassstangrookie is offline
Old 09-02-2010, 01:57 PM
alkemist
alkemist's Avatar
Gotcha. Where I was going at is choose the gear to stick with. Just swapping gears around, even with FRPP gear set raises the chance of whine.
alkemist is offline
Old 09-02-2010, 06:02 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
From what I have gathered 4.10's are pretty good with a centri style super charger
but for twin screws most people thing 3.73's perform better for them.
Blacksmoke is offline
Old 09-02-2010, 06:06 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Well of course it raises the chance... because if you don't have gear whine on stock gears there is virtually 0 chance that you will get it because you arent changing anything.
But when you change gears then you therefore have a chance lol.
They key is just to find a place with experience doing gears in these cars.
Get them to tell you if you do get whine they will fix it for you no charge.
Old 09-08-2010, 03:27 PM
So after a fair amount of reading and digging, this is the upgrade list I came up with, ordered by hp/dollar spent. I know the CAI and UDP will eventually come off for the turbo(i think). Witht he exception of those 2 parts do you guys see any other conflicts, or anything im missing on my list?
tuner
cai
4.1 gears
intake manifold
Musclecar Idle
throttle body
power aid body spacer ? may not be needed with a new throttle body
udp
heads
Steeda Charge-Motion Control Plates
exhaust(long headers,x pipes,mufflers)
turbo
Old 09-08-2010, 04:52 PM
808muscle
808muscle's Avatar
Read what others have in their sigs. That will help you realize what's common and works. TBs arnt worth it from what I've read.
808muscle is offline
Old 09-08-2010, 07:06 PM
StuckInNYForever
StuckInNYForever's Avatar
Originally Posted by rookieassstangrookie
tuner
cai
4.1 gears
intake manifold
Musclecar Idle
throttle body
udp
heads
turbo
If you are going turbo, all the rest may be pointless. Alone, that should max out your power quickly on the stock block. And your traction. Most good kits will come with the tuner and custom tune I believe. The only other mod you need may be drag radials. Feel free to disagree, but you will get 500rwhp (close to 600 at the crank) with this kit alone: http://www.hellionpowersystems.com/i...article&id=139
StuckInNYForever is offline
Old 09-08-2010, 07:08 PM
siggyfreud
siggyfreud's Avatar
Move throttle body down to the bottom of the list. You can put it before the turbo IF you decided not to do the turbo, but you really won't need it until you're into some decent power.
siggyfreud is offline
Old 09-08-2010, 07:49 PM
mayo
mayo's Avatar
Swap the tb with the exhaust setup and you have got yourself a great line-up!
Enjoy the ride.
mayo is offline
Old 09-09-2010, 08:07 AM
Thats true, I wasn't really thinking about maxing out the stock block, or taking it into account rather. That is a pretty nice kit, with a decent price. I am some what mechanically inclined, and will probably be doing a fair amount of the work with my dad. The instructions for the install dont look too bad, mostly bolt on, is it an install your average stang owner could probably handle? Tool wise the only thing I think we are missing is a lift, but I guess that isnt completely necessary, all be it nice.
Quick Reply: New Mustang Owner needs direction!!
