postive battery problem
Old Sep 10, 2010 | 10:19 AM
stealth32's Avatar
stealth32
Default postive battery problem
Hey guys my positive battery has blue powder like stuff coming out of it is this anything I need to be worried about or can I just clean it up
Thanks
Old Sep 10, 2010 | 02:53 PM
Nuke's Avatar
Nuke
Usually, battery terminal corrosion like you describe is due to the battery offgasing and the gases escaping at the location of the buildup. Try cleaning it up with water and baking soda, dry everything well and put it back together. If it happens again you're probably in need of a new battery.
Some folks here were able to get their Ford dealer to pony-up (no pun intended) a new battery under warranty.
Old Sep 10, 2010 | 03:44 PM
Goldenpony's Avatar
Goldenpony
corrosion around battery terminals is from an acid leak at that point. As Nuke said, you can clean it with some warm water with some baking soda in it. I've had some success with the felt washers. As Nuke said, if it keeps coming back, it's new battery time.
Old Sep 10, 2010 | 04:12 PM
Nuke's Avatar
Nuke
Acid, gas... I knew SOMETHING was escaping...
Old Sep 17, 2010 | 11:16 AM
157dB's Avatar
157dB
Cut & Paste Expert
Clean with THIS then....
CRC Battery Terminal Spray has kept the
blue fuzzy corrosion away for about 2 years now.
Any reputable parts store has it.
Avoid the baking soda cus if one molecule of it
gets into any one of the 6 cells, its T O A S T.
If it can leak acid out, it can let baking soda in.
Overgassing is a by-product of over-charging.
Something else is wrong besides the battery leaking acid/gas...
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
