couple questions
couple questions
my 2007 gt is at 31k miles, and i'm starting to see that i'm decreasing in mpg...i drive the same(not too heavy, but not too soft) and i keep the correct pressure in the tires...i have heard ppl say they changed the fuel rail at a certain mileage(im pretty sure that's what was mentioned) would this help me at all?
When WAS the last time you checked tire pressure? Now that it's getting cooler, you could be 4 PSI low if you haven't checked it since the temps dropped by 40 degrees. Or it could be the winter fuel that may be showing up. Or both...
You can't see the fuel filter; there's a plastic "plate" over it. But it's about directly below the drivers seat. You have to remove a few clips to get to it. I used my ramps on the one side of the car. Besides, you can do it when you do your OWN oil change.
