2005 GT Automatic, Launch Techniques?
Old Oct 21, 2010 | 05:32 PM
808muscle's Avatar
808muscle
Traction at my track is always better then the street. Just try different techniques, you will find what works best at your track. Deep staging always gives me a better RT too.
Old Oct 22, 2010 | 02:31 AM
stealth_GT's Avatar
stealth_GT
^ 808, Did the cams really make the auto sluggish off the line, even power braking it??
that sucks.. no tune fixes that??
I may be getting cams along with an intercooler, pumping out 10 psi.. I don't want crappy off the line performance with cams installed. That'll just be another problem to fix! rofl
Old Oct 22, 2010 | 04:03 AM
Tylus's Avatar
Tylus
your best bet really is getting wider tires. the 235 width stockers aren't even adequate for the V-6 guys
as your car sits right now, tire pressure and power braking are all you can do. hope you have fun at the track. really wish we had one out here so i could see what mine would do.
Old Oct 27, 2010 | 02:44 AM
desslok40's Avatar
desslok40
Get drag radials, upper control arm, lower control arms with relocation bracket.
sub 2 second 60 fts all day, my personal best is 1.81 sec
Old Oct 27, 2010 | 09:38 PM
tx_zstang's Avatar
tx_zstang
That's for sure! Cant' tell you how many times I spun with the stock GT Pirellis; way too many times, too many close calls. DR's took care of that and made the launching that much more safer and predictable.
Old Oct 30, 2010 | 07:41 PM
Swarz_kopf's Avatar
Swarz_kopf
Ran today. Aired the stock 235/55/17s down to 24 PSI. Managed a 1.98 60' and a best ET of 13.27 @ 104.5 MPH.
Car has a JLT CAI and Bama 93 octane tune- that's it- otherwise totally stock.
Old Oct 31, 2010 | 09:00 AM
mayo's Avatar
mayo
Your run reconfirms what has been said before....MORE RUBBER is needed!
With my stockers and a tune, I use a combination of techniques so I don't blow up the rubber...
Stage stall up to wheel spin, as soon as the tires break loose release brake and roll into the throttle as opposed to wot. Once you get to wot...pin it! Seems to alow the tires to catch a little quicker at the top end of 1st gear.
Keep in mind im just havin fun at red lights and don't time myself, but I do now the quicker you hook up, the better your times will be.
Nothing a couple of 285's out back won't solve...right!
Old Oct 31, 2010 | 11:43 AM
Swarz_kopf's Avatar
Swarz_kopf
How do my four low 13 second passes at all confirm that "more rubber is needed"? I wasn't spinning at all. I was real pleased with 13.27 out of an automatic '05 GT coupe with two modifications and was fine with a 1.98 60' on 5 year old, 235 series street tires.
I need more rubber for the street- but at the track the car did great on the Pirellis.
Old Nov 6, 2010 | 04:37 PM
JimsGT's Avatar
JimsGT
I have an '06 GT auto, I have a tune/CAI, and at the time, 3.73 gears, GT 500 LCA's, and I ran on stock 17" Pirelli's. I would just keep it at 1800-2000 rpms, and when its time to go, just let off the brake and floor the gas! My best was 13.1 @ 105, and 60 ft's between 2.00 and 2.02 ( I also went around the burnout box) Usually by the second run the tires felt better, on the first run its kinda scary!
TCStangerv6
Oct 11, 2015 05:57 PM
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
