Suporting mods
Old Nov 19, 2010 | 07:40 PM
Fuel's Avatar
Fuel
Default Suporting mods
I am going to be ordering a turbo kit for my car within a month or two and am just wondering what on the car needs to be upgraded to safely run at about450rwhp(ie. fuel pump, injectors, MAF, etc.)
thanks guys
Old Nov 19, 2010 | 07:52 PM
SpartaPerformance's Avatar
SpartaPerformance
You should buy a complete kit with the proper MAF, injectors, plugs and pump. Turbonetics makes a great one.
Old Nov 19, 2010 | 08:14 PM
RAT281's Avatar
RAT281
I don't think there is such thing as safe and forced induction. More power almost always equates to more broken parts.
Old Nov 19, 2010 | 08:32 PM
Fuel's Avatar
Fuel
okay, so how about properly run a turbo kit?
Old Nov 19, 2010 | 08:41 PM
RAT281's Avatar
RAT281
at 450 you are right on the fence for needing a gt500 fuel pump. I would avoid a BAP at those levels. Personally I feel like its putting a bandaid over a potential issue
Old Nov 19, 2010 | 08:46 PM
Fuel's Avatar
Fuel
Thank you very much for the info, as I have researched and found that the BAP is the way that most people go. I really don't like the BAP for the same reason. Is the GT500 pump a direct replacement or does it require some cutting and splicing to put in. Also, could you give me an idea on what size of injectors I will need for this aplication?
Old Nov 19, 2010 | 09:16 PM
RAT281's Avatar
RAT281
38 lb/hr should do the job
Old Nov 19, 2010 | 09:18 PM
RAT281's Avatar
RAT281
No cutting or splicing with the dual gt500 pump. should be around a 4 hour job. What turbo are you going with? You may want to consider a fuel pressure guage as well
Old Nov 19, 2010 | 09:42 PM
Fuel's Avatar
Fuel
I am going tobe going with the ON3 kit with the MP T70 turbo. Do I need dual GT 500 fuel pumps or just one and does this require the wiring upgrade. ALso, will I need to upgrade my MAF for this kit?
thanks
Old Nov 19, 2010 | 10:08 PM
RAT281's Avatar
RAT281
def need to upgrade MAF. gt500 fuel system is a dual fuel pump. You may be fine with a BAP, but try to think long term. If you are going to up the boost later down the road just go with the best fuel system you can.
