cai
Old Nov 27, 2010 | 05:57 PM
pdiddy1's Avatar
pdiddy1
Default cai
Just put in roush cai and now getting engine light,before I bought it I contacted roush and asked them by putting it on would I have to get a programmer or would it be fine? They said no programmer was needed and I took off battery terminal for ten minutes to see if that would reset computer worked for about ten minutes the light came back on. Any answers???? Thanks
Old Nov 27, 2010 | 06:30 PM
SpartaPerformance's Avatar
SpartaPerformance
Usually the CAI's that can be used with or without a tuner comes with a little restrictor that you must install if you use it without a tune.
D'prived's Avatar
D'prived
Take it to AutoZone to have them check for codes. Adding a CAI shouldn't have any effect on the engine itself. It may be something else that not right but didn't show up until you added the CAI.
Old Nov 27, 2010 | 06:31 PM
Nuke's Avatar
Nuke
Even with a no-tune required CAI, some cars will still throw a CEL for running lean. Do it right and get a tune. A stand-alone CAI is about worthless, gaining maybe 4-6 RWHP. With a good custom tune (NOT the canned tunes from Diablo and SCT) you can pick up about 20-25 RWHP plus improve overall driveability.
But I thought the Roush CAI required a tune...
Old Nov 27, 2010 | 06:36 PM
SpartaPerformance
Not true. On OBD II cars if you surpass the preset parameters it will throw a CEL
Old Nov 27, 2010 | 06:39 PM
D'prived's Avatar
D'prived
But not completely true. How do you know your surpassing the preset's? I installed a CDC Shaker and then months later a Ford Racing CAI without throwing any CEL's.
Old Nov 27, 2010 | 10:13 PM
SpartaPerformance
Ford Racing CAI has less air flow then aftermarket units such as JLT, C&L etc... 85mm with a rubber inlet with factory style difussers.
Old Nov 28, 2010 | 09:17 AM
ski's Avatar
ski
Uninstall and reinstall the CAI, making sure all connections are tight, the MAF is correctly installed with its rubber gasket in place, and the PCV line is connected.
Jb145700
Aug 21, 2022 06:37 AM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
junior04
Sep 28, 2015 10:53 AM
firecoyote
Sep 27, 2015 02:37 PM
