I NEED HELP!!!!!!PLEASE
Old Mar 2, 2011 | 06:40 PM
DanielsDad's Avatar
DanielsDad
Default I NEED HELP!!!!!!PLEASE
I have a 06 gt with 34000 miles. The car will not shut off when you turn the key off.. you can even pull the key out and it keep running. Radio stay on lights ever thing. I drove it one day every thing was fine got in the next and this... PLEASE HELP
Old Mar 2, 2011 | 10:11 PM
alkemist's Avatar
alkemist
The accessories stay on until you open a door.. or when 10 min hits, the shaker 500 will shut off due to preventing battery drain. Not sure if that is what you are referring to? The owners manual will tell you all about it.
Old Mar 3, 2011 | 03:04 PM
DanielsDad's Avatar
DanielsDad
No thats not the problem. I Can turn the car off and pull the key out and it keep running...Door open, Closed. it does not matter it will not shut off the radio will stay on until the bat dies
Old Mar 3, 2011 | 04:56 PM
ShaneM's Avatar
ShaneM
sounds like some sort of ignition switch issue.
Old Mar 3, 2011 | 07:26 PM
JIM5.0's Avatar
JIM5.0
As much as I hate to say it, but you will have to take it to the dealer or some other shop that can fix it.
Old Mar 3, 2011 | 08:18 PM
Nuke's Avatar
Nuke
+1
And I've never heard of the water leak issue causing that severe of an issue with the SJB that the engine won't shut off.
Old Mar 3, 2011 | 08:23 PM
ShaneM's Avatar
ShaneM
Originally Posted by Nuke
+1
yeah i'm betting something in that ignition switch broke and it's no longer telling the car to turn off when you turn off the key.
Old Mar 5, 2011 | 02:23 PM
157dB's Avatar
157dB
Cut & Paste Expert
Most likely it the switch gone bad.
Replace it before it leaves you stranded.
Old Mar 5, 2011 | 05:27 PM
DanielsDad's Avatar
DanielsDad
Hey Everyone Thanks for the help, but it seemed to be the water leak i cleaned everything is fine now.... now i'm ready for Cams how do you guys think i need to go and ps sniper tuning sucks dont spend mony on it
Old Mar 5, 2011 | 07:54 PM
alkemist's Avatar
alkemist
If it's the water leak for some reason.. it will be chronic until you stop the leak. Cleaning it is only a temporary band aid.
