How's it going guys? Build thread.
Old Mar 18, 2011 | 08:06 PM
Fuel's Avatar
Fuel
Default How's it going guys? Build thread.
It has been quite awhile since I have been on here and when I used to be on here it was the New Edge section that I spent most of my time in. I haven't really been around here since getting the s197, but since I used to be on here all the time(and thought some of you might remember me) I thought I would share my story of my new car's progress.
I got this car in november. It was a one owner completely stock 2008 GT with 43k miles on it. Since I parked it for the winter I have started to install an On3 turbo kit with master power T70 turbo. The car will be running a GT500 fuel pump kit, 80lb FRPP injectors, PMAS HPX MAF, CMDPs, and tuned on E85. I hope to have the rest of the little stuff installed in the next week or so and then it is on to the tuner.
Here are some pics to enjoy.
Old Mar 18, 2011 | 10:24 PM
daredevil95's Avatar
daredevil95
Hi, nice work. How would you rate the install/fitment of the system?
Old Mar 18, 2011 | 10:34 PM
Fuel's Avatar
Fuel
The install went well. I think that the instructions leave a lot to be desired but if you have some decent mechanical ability and aren't worried about taking your time to adjust the pipes and what not it is a very good kit. I don't mean that the kit has any problems, you just need to take your time and make sure you install it properly, just like anything else that is this extensive of a mod. Overall, very happy with the kit.
Old Mar 18, 2011 | 10:58 PM
daredevil95
Cool. I agree....looks like fun! I like the design of this system.
Is the On3 a 5lb system? Once you start it let us know how it sounds/works?
I don't know much about the latest turbos but, the rear mounted turbos scare me. Plumbing all the way to the back wheel seems distant for lack of a better word?? Seems like a lot of connections to tighten every month, plus wear and tear from the roads. The rear mounted turbo's sound great when I'm driving next to one. Your kit is the first front mounted turbo I seen for the S197. Good luck
Old Mar 18, 2011 | 11:18 PM
Fuel's Avatar
Fuel
I am a member on another mustang forum site dedicated specifically to s197s and theri are a few guys their that run this turbo kit. THey say that after it is installed and you heat cycle it, give it a once over to make sure everything is still tight and then you are good to go. I believe that the waste gate comes with a 6lb spring in it and you get more springs with the kit to add more boost. I also bought a manual boost controller and the extra springs and boost controller will be going with me to the tuner to dial it in. I also bought a set of cherry bomb extreme axle back mufflers to go on the car.
I would definetly stay away from the rear mount turbo kits. Not only do you have to worry about the piping all the way back there and then back to the engine, but think about the turbos. You have to run oil lines all the way to the back of the car to lubricate and cool the turbos. Then you have to run a scavage pump to pump the oil back to the engine after it leaves the turbos. If that pump fails then so could you turbos or engine for that matter.
Old Mar 18, 2011 | 11:46 PM
daredevil95
Sounds great...hope to hear dyno results from you!!!
Old Mar 19, 2011 | 01:23 AM
stealth_GT's Avatar
stealth_GT
Thats a great looking kit.. how much power are you making to the wheels??
Old Apr 7, 2011 | 08:24 PM
Fuel's Avatar
Fuel
Not tuned yet, but appt for tuning is set for the 12th. Can't wait to get some numbers!
Old Apr 7, 2011 | 10:09 PM
daredevil95
Good to hear from you.....I look forward to hear your numbers. I like that front mounted turbo kit. Maybe a short vid?
Old Apr 13, 2011 | 07:53 PM
Fuel's Avatar
Fuel
numbers are in guys, stayed conservative for a little while
Mustang Dyno numbers on 6.5 psi
411hp
418ft/lbs
Feels like a whole new car! There is plenty of room left with the fuel and MAF. I think that he said the timing is at 17 iirc. It was about 8:00 when we quit and I had a 3hr drive back home yet so I didn't want to spend anymore time there yesterday messing with a boost controller or changing springs so I told him to just leave it there. I will probably go back and up the boost a little once I get used to it like this and get some suspension parts to help plant the new found power!!
I thought I would share my cost list to complete this build so here it goes. . .
Valve Cover Breathers New $68
Boost Gauge Ebay $39
Boost Controller New (didn't use) $70
FRPP 80lb Injectors Used $260
On3 Turbo Kit w/ MP T70 Turbo and HPX MAF New $2530
CMDP $70
Heat Wrap New $27
Oil Restrictor $13.50
GT500 Fuel Pump Kit $630
Xcal 3 and HTOs Used $300
Roush Vent Pod New $33
Cherry Bomb Extremes Used $75
Tune $500
Misc Fittings $50
Total $4665.50
__________________
