Check Engine Light
About a month ago I:
-revved the engine on a cold start, then the check engine light came on
-cleared the code, which was P0153, and it never came back on
Since the check engine light has not turned on again, is it safe to assume that the car is fine? BTW, I have about 50k miles on it.
slow response code for the front O2 sensors. But since it went away I suspect it was simply a minor anomaly. I wouldn't worry about it unless it returns, providing you haven't touched your cats and O2 sensors.
no, nobody's touched anything in front of the h-pipe. I did, however, take a look to see where the bank 2 sensor 1 is located (driver's side on the manifold). if/when it goes out, how would I go about replacing it? it's in a horrendous location.
