Remove Sway Bar Link From Strut
Old Jul 16, 2011 | 05:35 PM
carockwell's Avatar
carockwell
Default Remove Sway Bar Link From Strut
Going to replace the front struts with new Bilsteins next week. One problem I have had with other cars I have owned is removing the ball joints on the sway bar links from the front shock struts. The way I have used in the past is to hit each side of the ball joint with two hammers at the same time. For some mystical reason this helps pop the joint out. Has anyone found this to be successful on the Mustang sway bar link joints? If not, what method did you use?
Old Jul 16, 2011 | 06:56 PM
Simon1's Avatar
Simon1
18 mm and 8 mm sockets or ratchet wrenches. No hammer or banging required.
Old Jul 16, 2011 | 09:25 PM
carockwell's Avatar
carockwell
You mean that ball joint just pops right out after you remove the retaining nut? That'll be the first car I ever got that lucky with.
Old Jul 16, 2011 | 11:12 PM
JAJ's Avatar
JAJ
What year is your car?
On a 2011, you hold the upper ball joint stud with a 17mm OE wrench, you undo the nut with an 18mm deep socket, and it just comes apart when the nut is off.
Do the earlier cars have a weird arrangement for the links?
Old Jul 17, 2011 | 01:58 AM
Simon1's Avatar
Simon1
Correct. To completly remove the end link on the sway bar for 2005-2009, maybe 2010, the tools recommended above will do it.
When you put it back together, I would suggest putting some locktite on the threads.
It's really very easy.
Old Jul 17, 2011 | 08:58 PM
carockwell's Avatar
carockwell
No, it is just my inexperience with the Mustang. Every car I have seen before uses a tie rod (or ball joint) that is a tapered fit into the hole. When you tighten the nut, the tapered shaft "locks" into the tapered hole. A well known secret to getting the tie rod out is to tap it on both sides with two hammers at the same time. This creates a vibration that releases the tapered shaft from the tapered hole. The problem with this technique is that it only works 90% of the time. The other times require a puller, or tapered fork to remove the tie rod, and this often ruins the tie rod's plastic cover. Having never been up close and personal with this part of the Mustang, I just assumed the links were attached using tapered fit tie rods. Apparently the sway bar link ends are something different. Great! Should make life easier because I don't have to find the correct puller from all my tools stashed in storage.
Old Jul 18, 2011 | 11:21 PM
Simon1's Avatar
Simon1
Really, it should take less than an hour of labor to remove and reinstall the front springs and struts. I had never done it before and figured it out on my own.
jwog666
Dec 27, 2021 08:09 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Sep 16, 2015 07:53 PM
Sep 10, 2015 08:39 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
