Adding extra HX, reservoir and 3 fans - No effect so far on IAT at 70 ambient temps
So I have heard so much about adding fans to the Afco or equivilent heat exchanger. I added a separate IAT sensor in the front driver side plug on the Kenne Bell lower intake.
I setup 3 fans to pull through the 2 heat exchangers.
I put in the Moroso Reservoir for the GT500. Added another HX. I added just over a gallon to the system by doing this.
Also a new Johnson CM20 pump.
The flow is great. Moves fluid at a good pace to cool.
System is purged.
The air temps after driving for 15 minutes then sitting at idle are exactly the same with the fans on for another 15 minutes.
Same temperatures when driving around town.
Temps go to 148 and stay pretty constant.
I have a Roush front bumper with plenty of directed air.
Really disappointed. I figured I would see a 20 degree difference.
System is purged.
Ouch man. Sorry to hear that. I'm about to do a battery relocation and add a larger intercooler reservoir in the stock battery location. I hope I get results. Will let you know. Might be a couple of months before I get the project off of the back burner...
A few thoughts:
- Is it possible that the sensor you're reading is somehow picking up the temperature of the manifold casting (which would be around 150 degrees or so) and not the air inside it?
- Have you checked the temperature of the coolant in the HX system? Just stick a thermometer in it. If it's running cool like it should be then I'll bet your intake is a lot cooler than that sensor is telling you.
- Does your ECU have an IAT sensor and if so, what does the ECU IAT read?
- Are you sure the sensor you added is after the internal heat exchanger? If it was on the output of the blower directly before the HX, all the cooling in the world won't change the reading.
Keep us posted...
The IAT on the SCT scanner and the gauge stays within 1 degree of each other.
The sensors are in the front driver side port in the intake manifold.
Its hard to say at what point the reading is without taking apart the blower and looking at the ports. I believe the sensor is in the spot Kenne Bell recommends.
It may be post charge and that is why the IAT seems so high.
I do not see any other ports to use though.
The strange thing is the fluid is cool after driving for 30 minutes today.
The IAT was 158 off of both sensors, but the fluid felt about 80 degrees in the tank. I can put an infrared reader on it, but it was no more than that.
I can pull a piece of foam into the grill from 6 inches away with the fans on, so they are definiately pulling hard.
I'm no expert in supercharger cooling, but I've built some really big thermal management systems in my time. It sounds to me like you've got enough cooling on there to keep the temperatures down. The fact that you're not seeing lower readings suggests to me that your instruments are not working properly.
A few thoughts:
Keep us posted...
A few thoughts:
Keep us posted...
The fluid is cool/warm to the touch in the reservoir after 30 minutes of driving.
I was going to do the battery relocation, but I have the Shaker 1000 and wanted to keep some space in the trunk.
The moroso tank and extra HX gave me a good increase in fluid.
UHM?
So you are worried because the air temp in front of the blower hasn't changed even though you added extra intercooler capacity which cools the air after it exits the supercharger?
Of course the air at the intake of the blower isn't going to change, you're not cooling that, you're cooling the hot compressed air coming out of the blower.
UHM?
So that is why I am concerned that I have no change in the IAT's with the fans on or off...
Maybe the KB just runs this hot.
It has been suggested I have a flow issue, but the liquid is moving well in the reservoir.
This is where the KB puts the IAT sensor. Cylinder 5.
Uploaded with ImageShack.us
Okay, from the original post, it read the other way.
Only thing I can say it that at idle you shouldn't be in boost and the intercoolers shouldn't have much of an affect on IAT.
Do you have any measurements of ambient air? Could it be that your IATs stay lower when in boost?
