Will 305/35-20 nittos nt555r fit on rear? or go with Toyo r888 285/35-20
I have 20X10 TSW 40mm offset rims on the rear of my 2006 GT Conv.
I have H&R race springs that lowered the car about 1.5"
Does anyone know if 305/35-20 Nitto Frag Radials will fit? Nitto says that they will fit the rim, but be a little tough to get on.
If they don't fit I guess I will go with the Toyo R888 285/35-20's. I was thinking the 275/40-20 Nitto is going backwards.
Any thoughts or experience with this?
Thanks.
Thanks.
This is a 305/40-18 nt555r on 10 inch rims. The springs are Steeda Ultralights which give about a 1.5 in drop.
A 305/35-20 would be approximately .8 in taller (so about .4 inches closer to the fender then the pics. )
I hope this helps.
Thanks for the pics. That is exactly how far out i pictured them.
I am a little worried with the 20's being to close to the fender now.
I will look intothe offset in your rims to compare to mine.
[/B][/B]
[/B][/B]
Are those the Nitto 555r's? Are they that bad for side to side handling?
Would they decently hook up with aprrox 600 rwhp? I figure you have a good amount of rwhp.
if you have 20X10.5 inch rims, they are .5 inch bigger than mine.
With a 45mm offset, your rim sits .25" inward more than mine.
So I think our rims both sit in the same place on the outside by the fender.
It may work... I don't want to buy new rims again...
Thanks Mellow!
