Any ideas on how I can pass my emissions test?
Took my 09 GT in to get tested today and it got rejected. My catalytic converter eff., evaporative control system, heated oxygen sensor, and oxygen sensor are all NOT READY. All my mods are listed below. I have high-flow cats on it by the way. Thanks.
I'd suggest making everything "READY" then getting it tested.
If your monitors are not ready to me it means the battery either went dead or just replaced, if that is the case then you need to drive both local and highway for about 50-60 total miles. IF the dead or replaced battery is not the case then that to me means whoever tuned it turned off the rear O2's.
Oh really? Yea I got my tune from brenspeed as well. I will have to give them a call tomorrow. Did all those other systems come up as NOT READY on yours as well or was it just the O2 sensor?
They told me they turn of the O2s unless you ask to have them left on.I can't remember what all was off.I told them I had to get through emissions. They sent me a new tune and I drove it a couple days to get everything back to readyness for testing.
OP-Ask them if they can send you an emissions tune.
*and of course they fixed it after a quick call
You need to turn on your rear 02's sensor or you will never be ready. You usually need 3 out of 4 to be ready.
If you have cats, you will be fine 99% of the time.
If you do not have cats, you need to move the rear 02 sensors out of the exhaust stream using a non fouler, 18mm I believe.
Drive the car normal for about 40 to 50 miles. Not to hard, not to light.
that should do it.
that should do it.
