help with headers
Old Mar 25, 2013 | 07:21 PM
blkgt08's Avatar
blkgt08
Default help with headers
I have a 08 gt 5 spd. I wanna purchase long tube headers soon but unsure ofthe best to get. I'm thinking either kooks, american racing, or hooker. Which fit better and what size should I get. Also, is it worth getting the 62mm throttle body
Old Mar 25, 2013 | 07:30 PM
CMcNam's Avatar
CMcNam
Do you have any other mods to complement the headers?
Do a quick search of aftermarket throttle bodies and you'll find they add nothing and are wrought with issues. I haven't seen one review on here that says they're worth anything to a car that hasn't been heavily modified first.
Old Mar 25, 2013 | 07:35 PM
DocSnickers's Avatar
DocSnickers
If you switch headers your going to want to look at doing the rest of the exhaust system too. Headers won't do much good on a stock exhaust system need the rest of the exhaust to breath.
Also going longtube headers may require a tune on the car, least it does with the 2013's. I would assume your car would too.
Old Mar 25, 2013 | 08:35 PM
Suicide Bobb's Avatar
Suicide Bobb
I know for sure that Kooks and ARH will fit very well. No idea about Hooker.
Throttle body worth it? No. You'll gain at most 10hp (and that's if you had FI), the factory unit does fine until 500hp or so.
You should definitely do a full exhaust, assuming you didn't already plan on it. I picked my midpipe first, then the headers from the same manufacturer to ensure a painless install. Of course, I was quite picky, only considering exhaust from either MAC, Bassani, BBK, JBA, Kooks, and ARH. I spent weeks (literally) researching until I found what I wanted and for the lowest price possible. It's one of those things you only want to have to replace once.
If you're replacing the exhaust yourself, don't forget to add in the cost of the tools you'll need. Depending on what you currently have, that amount could exceed $100 (with good tools, not harbor freight crap). Start spraying all the screws and nuts you will be removing today, everyday until you start the swap. Overkill, maybe, but you do not want to be stuck 10min into the job with a snapped stud on the starter like me...
Old Mar 26, 2013 | 02:47 AM
808muscle's Avatar
808muscle
Header install is a long job. Took me with help an entire weekend. Its just nuts and bolts but its a lot of them. A 13mm flexhead ratcheting box wrench is a absolute must. Gloves are too.
Old Mar 26, 2013 | 07:07 AM
blkgt08's Avatar
blkgt08
I have a cai and its tuned. Off road h pipe with flow masters. I'm leaning more towards kooks long tube with x pipe. Does kooks offer a ceramic coated header?
Old Mar 26, 2013 | 07:15 AM
S197GT07's Avatar
S197GT07
You can get them coated, but it doesn't matter since they are a good quality SS. They will just look pretty.
ARH > Kooks IMO though, they are a full length longtube and not mid-length like the kooks.
Old Mar 26, 2013 | 07:22 AM
jpplaw's Avatar
jpplaw
As far as Kooks go - if you want your car to sound like a Ferrari, get the x-pipe; If you want it to sound like a musclecar, get the H.
Old Mar 26, 2013 | 11:52 AM
ghunt's Avatar
ghunt
FWIW, the Hookers are mild steel and will rust, ceramic coating or not. I think they're a little overpriced considering that they are just mild steel.
I just installed a set of ceramic JBA's, they fit like a glove, but part of the reason I got them was because of the great deal I found on them too. I was glad I wasn't on a particular timetable for the install either- I had a lot of trouble removing some of the original hardware (especially the dipstick tube), and had an issue with one of the bolt holes on one header being off JUST enough that the bolt wouldn't start, and had to fix that. Otherwise pretty easy overall, just time consuming.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
