Is this worth buying??? cold air intake
Old 10-06-2005, 07:19 PM
FastBackDan
FastBackDan's Avatar
Default Is this worth buying??? cold air intake
I saw this on ebay and was woundering since you are not changing out the MAF would you need to flash your computer? Is this pretty much the same as a drop in K&N filter? I can't buy a cold air kit yet with, but was going to aleast do a K&N filter untill I saw this. Also would the HP gains be about the same as the K&N filter?
http://cgi.ebay.com/ebaymotors/MAC-S...03963289QQrdZ1
FastBackDan is offline
Old 10-06-2005, 08:40 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: Is this worth buying??? cold air intake
ORIGINAL: FastBackDan
You will NEVER see 20hp from a filter change. Even a tuned intake won't give you that kind of gain. 90% of the CAI's our there are good for maybe 2-3hp tops including K&N. Save your money, remove the carbon trap in the intake and get a flash tunner. The trap removal and tune will give you about 10-15hp at the crank on the 05/06 Mustang GT.
Derf00 is offline
Old 10-06-2005, 08:43 PM
FastBackDan
ORIGINAL: Derf00
I'm new to FORD and have had chevy's all my life. What is the carbon trap? in the air box? also should I just get a drop in filter and do the mod that you are speaking about? Thanks Dan
Old 10-06-2005, 08:55 PM
TexaStang
I ♥ Acer
TexaStang's Avatar
C&L intake kit with a tune is worth quite a bit more than 2-3hp bro....
TexaStang is offline
Old 10-06-2005, 09:57 PM
FastBackDan
Can someone point out where the carbon filter is, thanks Dan
Old 10-06-2005, 10:54 PM
TomsEleanor
TomsEleanor's Avatar
ok, since noone would answer the question in my post, ill ask here. did ford delete the carbon filter for the 06 GT's? i have looked for mine, and i DO know where it should be, but it isnt there on my 06. anyone have any input?
TomsEleanor is offline
Old 10-06-2005, 11:03 PM
drbobvs
drbobvs's Avatar
Yes, Ford deleted the air trap mid production cycle of '05
drbobvs is offline
Old 10-06-2005, 11:38 PM
FastBackDan
I just bought mine 2wks ago. It was ordered for someone and not sold, so I guess I should look at the built date in the door jam right? If it's been built 2-4 mos agao I should be ok? If not where is the carbon filter located?
ORIGINAL: drbobvs
Old 10-07-2005, 12:02 AM
TomsEleanor
thanks drbob, appreciate that. fastback, itll be in the intake line just behind the air box. looks like a white piece of cotton if im not mistaken. hope that helps.
Old 10-07-2005, 10:34 AM
Robs05gtvert
Robs05gtvert's Avatar
my build date was April and it did not have the carbon filter.
Robs05gtvert is offline
Quick Reply: Is this worth buying??? cold air intake
