weird electrical issue
Old Jul 15, 2013 | 02:01 PM
flash_xx's Avatar
flash_xx
Default weird electrical issue
Hi,
I don't really know how to explain this, but I went to the track saturday and while running the 1/4 mile my brake lights came on for just a second a couple of times in all runs. Someone took a video of one run, I think the video shows it really well.
Anyone have any idea what might be causing this?
Old Jul 15, 2013 | 02:03 PM
Nuke's Avatar
Nuke
Are you familiar with the TSB for the water leak? It affects the SJB and eventually causes numerous electrical gremlins.
Old Jul 15, 2013 | 02:16 PM
flash_xx's Avatar
flash_xx
Yes, the SJB is dry, mine doesn't have a leak.
Old Jul 16, 2013 | 01:06 PM
Mr.Ski's Avatar
Mr.Ski
Your brake pedal postion switch may not be seated properly. When installed it goes through the bracket and then you turn it about an eigth of a turn and lock into place. When it locks in place there are 2 black ears that need to pop into place once its locked. Make sure that you do not press down on the brake pedal when installing the switch. If whoever originally installed the switch pressed on the pedal when they did it, the brake lights coming on is one of the results. The switch comes out the same way. Try turning it and see if you hear it lock into place.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
LiquidDrink
Sep 29, 2015 10:06 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
