Hood shake
Old 07-11-2013, 07:46 PM
BillE
BillE's Avatar
Default Hood shake
I have a 2008 Mustang GT minor up-grades and was taking a trip and wanted to see what its top end is, the problem is when I hit 125mph the hood started to shake so hard I thought it might fly off. Is this common or because of turbulence because it is stock ride height.
BillE is offline
Old 07-11-2013, 07:48 PM
CPTCO
CPTCO's Avatar
I would say its somewhat common. I've taken mine well past that speed, the shake is a little scary for sure. You can get some hood pins if its that bad.
CPTCO is offline
Old 07-11-2013, 08:06 PM
Ricardo
Ricardo's Avatar
Same here. Strong crosswinds on the freeway make it shake bad. It'll stay shut. You can adjust the rubber stops up to make it sit tighter when closed. Some get pins and those alleviate it.
Ricardo is offline
Old 07-11-2013, 09:06 PM
BillE
BillE's Avatar
Thanks, always good to ask. First mustang so far its a great ride
BillE is offline
Old 07-11-2013, 09:51 PM
CPTCO
CPTCO's Avatar
Man, if the hood pops open going 150, what's the worst that could happen...no wait, maybe I'd better order some hood pins.
CPTCO is offline
Old 07-11-2013, 11:58 PM
BillE
BillE's Avatar
What would the worst that could happen think about it. I've done well over 125mph on my motorcycle and the plastic never shook but if it broke off could be the same results
BillE is offline
Old 07-12-2013, 03:55 AM
07 GT E UPP
07 GT E UPP's Avatar
Hood flapping like a bed sheet at high speeds is an age old problem with our (2005+) aluminum hoods BillE. Personally, I have never heard of any hoods flying off..... Try adjusting the front rubber bump stops and this should help some. But, For piece of mind, you can always invest in a set of good hood pins..
07 GT E UPP is offline
Old 07-12-2013, 05:30 AM
Rudolph Hucker
Rudolph Hucker's Avatar
never knew they made of aluminium..
why?
is it a weight problem
Rudolph Hucker is offline
Old 07-12-2013, 08:21 AM
Ricardo
Ricardo's Avatar
Ford went with it to save wieght on the front end on our nose heavy cars.
Ricardo is offline
Old 07-13-2013, 06:58 PM
Nuke
Nuke's Avatar
Hood shake on the S197's is VERY common. Try adjusting the rubber stops up about 1/2 turn, one side at a time. By virtue of this wonderful design, air is forced up under the hood, primarily at the headlights. Mine shook pretty bad at speeds over 90, wind speed/direction dependent. After a few adjustments, she's rock solid over 130.
Nuke is offline
Quick Reply: Hood shake
