Another tick/knock thread - but different?
Old Dec 11, 2015 | 11:03 AM
Tivo304's Avatar
Tivo304
Unhappy Another tick/knock thread - but different?
Afternoon everyone,
Yes, this is one of many 289 modular tick/knock threads... Only having read through others' posts and discussions, mine doesn't seem too common.
Long story short: 75K miles, 5 SPD, stock minus Flowmaster's and a short-throw. I've only had the vehicle for ~5 months, and only just recently started driving it daily. I don't beat on it, have only had WOT a few times, no slamming gears, etc... but it developed the dreaded ticks and knocks.
Yes, it has a top-end tick, which I'm certain is lash adjusters / phaser / some other commonality, fine. But I have a knock that's very pronounced on the bottom end. It comes from around the oil pan / trans to flywheel area, though I don't have a lift to get closer and specify more. Perhaps you can hear it here. You'll hear the top end, which is pretty isolated, but it's way louder underneath - hopefully my microphone picked it up. This noise only happens below ~1,800 RPM, I don't really feel a loss of power, but sometimes I feel a rough idle. But it is loud enough to hear it echoing in alleys, tunnels, next to parked cars, etc.
I do hear it coming through the mufflers ever so faintly. It doesn't do it when it's cold. Gets worse after stop-and-go / long drives. I recently put 5w30 full syn to quiet it down, which helped. Also ran MMO through it prior to oil change. Still pretty pronounced.
Thoughts? Possible common problems you've seen that cause this? Let it go? Wait for impending doom? This is now my daily driver, otherwise I wouldn't worry. And I apologize in advance for probably boring you... but right now, due to a lot of personal matters, I don't have the cash or the means to fix it... and if this thing goes, i'm !@#$ed.
Old Dec 11, 2015 | 12:26 PM
movielover40's Avatar
movielover40
It's nothing major like a rod knock.
Could be a number of things. Funny when it's cold you don't hear it. If it seems to stay the same your probably good.
Old Dec 11, 2015 | 12:43 PM
Tivo304's Avatar
Tivo304
THanks for your response. The whole "doesn't do it when it's cold" would lend itself to a top end noise, what with viscosity, oil temp, etc, wouldn't it? but it's definitely louder on the bottom end.
A spun bearing or main bearing would probably sound terrible regardless of temp, wouldn't it? I imagine it would also be way worse-sounding, and probably be worse the more the engine turns.
Old Jan 13, 2016 | 10:14 AM
Tivo304's Avatar
Tivo304
Update after couple weeks: This noise has gotten much more pronounced after long commutes. It's very audible in the cabin at idle if I have the air / radio off.
It's gotten cold here, snowed and is below freezing. Cold starts = no diesel noise. Warmed up after commute = very obvious. It got more diesel-y, but still seems to go away above 1,500 RPM. It's definitely not a very metallic knock, more of a tap / click, if that makes any sense. Changing all the spark plugs today to rule out that, since I've heard this being a cause of engine knock in the S`197. I'll also record the audio and get a more obvious version of the noise.
I know no one else has responded to this post, but I see loads of guys who get these similar issues. Figured I should contribute my own case for reference.
Old Jan 13, 2016 | 01:06 PM
SCCAGT's Avatar
SCCAGT
There is a trick to doing those plugs since they have a tendency to break. Best way my techs found to do these was as follows:
-Have the engine at running temperature
-"crack" open the plugs. That means just enough to break them free, no more than.
-put some PB Blaster or equivalent into the plug hole. More than just a drop or two. A fair amount. Let this soak overnight to soften up the carbon build-up.
-Go back and forth a couple times when initially taking out these plugs, then remove as normal.
-Once plugs are out, and none have broken off, remove fuel pump relay and turn over the engine a couple rotations to get excess fluid out, if there is any.
-Gap and install new plugs. If you use the Motorcraft as replacements, they are two piece, like the originals and will need this procedure followed again when its time. Champion makes 1 piece plugs. they don't break. Although they are also almost $20 each.
If you have not done, or heard about how different these plugs are, you should do a bit of research prior to embarking on something that can royally screw you over.
If the noise changes due to oil differences (weight, or temp), spark plugs will not have any effect on it.
Old Jan 13, 2016 | 11:08 PM
Tivo304's Avatar
Tivo304
Thanks for the tips. Got new motorcraft plugs in and the old ones came out without a hitch - PB Blaster did the trick. Unfortunately, no change to noise, but they needed replacing anyway.
Couldn't snap a video, phone died. The sound has become more specified in its location - it's actually more pronounced inside the cabin than outside the vehicle. Still an audible click / tick coming from the fenderwells and underneath though. It actually sounds most pronounced from underneath and behind the vehicle... but it's not coming through the pipes themselves. Could this be a sign of an exhaust leak?
Old Jan 14, 2016 | 04:30 PM
SCCAGT's Avatar
SCCAGT
In order for an exhaust leak to tick, it needs to be close to the engine. So, exhaust manifold crack, gasket, and Maybe the joint from manifold to mid-pipe. Anywhere else and it just makes the typical loud noise. At an idle, exhaust leaks are not very loud. Have to rev it or power brake to make it louder for pinpointing. Yes it can be heard inside, but would still be plenty audible when looking under the hood. Which begs the next question: Does it get louder when you accelerate vs idling?
In a different thread, someone has some fairly noisy injectors. Loud enough to hear with the hood closed. Do what he did to check those. An auto stethoscope or screwdriver placed on the front of the valve cover to rule out cam phasers. On the injectors to see if the timing of the clicks are in syn with what you hear outside. All the injectors will make noise, just gotta use both ears to tie them together.
If we cant get any farther with internet diagnosing, a shop visit may be in your future.
Old Jan 16, 2016 | 10:33 AM
Tivo304's Avatar
Tivo304
It does not get louder when accelerating, but stays consistent until above 1,500 - 2000, then goes away. It only does it once warmed up. It's not the injectors, I can hear them ticking away just fine on top of this noise. Bought a mechanic's stethoscope, hoping that helps me pinpoint it.
Old Jan 18, 2016 | 01:08 PM
SCCAGT's Avatar
SCCAGT
https://www.youtube.com/watch?v=HZuArjvEfRc#t=241
Old Jan 18, 2016 | 04:25 PM
movielover40
The car wouldn't have run this long if it was something major.
