PO352 Code
Old Jul 5, 2016 | 09:02 PM
BDPony's Avatar
BDPony
Default PO352 Code
Hello all, I need some help. I have a 2006 whipple supercharged GT. The car started to throw a PO352 code, car ran strong no misfires. I proceeded to change the coils, plugs ( HTO .032 ). The car continues to throw the code and sometimes throws the PO354 code also, now the car sometimes feels like its misfiring. So far I have checked the plugs, coils with a voltmeter and test light, also checked the coils with a spark tester, coil is throwing spark. I also checked the injectors with the screwdriver trick, all injectors are making the same clicking noise, so I don't think any are stuck open or closed. Today I rented a block tester kit and the liquid stayed nice and blue, so hopefully I can rule out Headgasket. So I guess I"m back to electrical, the only other thing I can think of is PCU, but if it was PCU wouldn't the coils be getting any signal? If anyone could give me some advice where do go from here I would appreciate it. Just one more thing, the car was taken to an electrical shop and after 2 hours the technician informed me it wasn't electrical, it was mechanical. Once again thanks for any help.
Old Jul 5, 2016 | 11:13 PM
jwog666's Avatar
jwog666
that is a code for the coil primary circuits on cyl #2 and 4. if the coils have been changed with good (OEM) coils on those cylinders then suspect wiring, connector pin fitment, and the pcm as causes
mirrormask
May 12, 2016 01:09 PM
98StANG4.6
Apr 30, 2003 07:27 PM
crod96
Apr 20, 2003 07:57 PM
98StANG4.6
Apr 20, 2003 07:55 PM
mygail
17
Apr 4, 2003 07:26 PM
