Help my GT is messed up
So right now my GT is very sick and I need to get her fixed it's my daily driver so I need it. A few days ago it started idling horrible the rpms would fall almost all the way off then jump up then fall and so on and so forth, also the car sounds like a lawnmower engine now doesn't sound good. Also smells like rotten eggs. There is a definite loss of power and some of my sensors aren't working. The codes it put up were a bunch of cam position sens. codes and 02 sensor codes.
So far I have replaced the alternator because when I did my research it said that was the usual culprit, however it didn't fix anything. Also I noticed the oil was very low(assuming it was burning) so I filled it back up. Car does have a few mods, k&n air intake, bbk 62mm throttle body, long tube headers, and cat back exhaust system. I need to get this fixed ASAP so any help is definitely appreciated.
Lukemitchell5590, what caught my attention was your comment about the smell of "rotten eggs." In my experience the smell of rotten eggs usually led to the catalytic converter. Have a competent mechanic do a "temperature test" on your cats. Hope this helped.
Your cats are clogged up but replacing them will only temporarily fix the problem. The real issue is the oil consumption and if that's high, it could be contaminating the cats.
Does your exhaust produce blue smoke?
When did all this start? Given your mods and the problems, it's not an overnight thing.
What work have you recently done on the car besides the alternator? Does the car have a tune, from who?
Yes, rotten eggs is cat related but that may only be a symptom of what caused them to fail.
The car did have a tune from superchips before I bought it but once I bought it the dealer took the tune off. I know it's bad but I've been driving it running lean for a few months until I could afford to get a tune. I might just take the cats off and see if it helps
A mechanic friend of mine said the cam phasers might be bad but I dont think that's it.
Get a tune on it that is made for your mods ASAP!
So I cut the cats out went straight pipe...it helped the engine run a little better but still sounds like a lawnmower and has trouble idling...I know the tune is a big part but there is something else wrong too...yesterday the low oil pressure light came on
please anything you guys can help with please let me know
I'll put a video of the engine running in a later post
