4:10 or 3:73s'?
#21
RE: 4:10 or 3:73s'?
Code:
Car Final Gears Standard Tire Size 2005 Mustang GT 5-Spd Man ( TR-3650 ) 3.55 3.38, 2.00, 1.32, 1, 0.68 235/55-17 2005 Mustang Auto ( GT / V-6 ) ( 5R55S ) 3.31 3.22, 2.29, 1.55, 1, 0.71 235/55-17 2005 Mustang V-6 5-Speed Manual ( T-5 ) 3.31 3.75, 2.19, 1.41, 1, 0.72 215/65-16 These are for TR-3650 with 235/55-17 and .0312% tire slippage and do not include aerodynamic drag
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 13.07 19.60 26.14 32.67 39.21 2cd 22.09 33.13 44.17 55.22 66.26 3rd 33.46 50.20 66.93 83.66 100.39 4th 44.17 66.26 88.34 110.43 132.52 5th 64.96 97.44 129.92 162.40 194.88
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 12.44 18.66 24.88 31.10 37.31 2cd 21.02 31.53 42.04 52.55 63.06 3rd 31.85 47.77 63.70 79.62 95.55 4th 42.04 63.06 84.08 105.10 126.12 5th 61.82 92.74 123.65 154.56 185.47
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 11.90 17.84 23.79 29.74 35.69 2cd 20.10 30.16 40.21 50.26 60.31 3rd 30.46 45.69 60.92 76.15 91.38 4th 40.21 60.31 80.42 100.52 120.62 5th 59.13 88.69 118.26 147.82 177.39
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 11.32 16.97 22.63 28.29 33.95 2cd 19.12 28.68 38.25 47.81 57.37 3rd 28.97 43.46 57.95 72.44 86.92 4th 38.25 57.37 76.49 95.62 114.74 5th 56.25 84.37 112.49 140.61 168.74
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 10.79 16.18 21.58 26.97 32.37 2cd 18.23 27.35 36.47 45.58 54.70 3rd 27.63 41.44 55.25 69.07 82.88 4th 36.47 54.70 72.94 91.17 109.40 5th 53.63 80.44 107.26 134.07 160.89
Code:
Speed in Gear @ RPM RPM 2000 3000 4000 5000 6000 1st 10.17 15.26 20.35 25.44 30.52 2cd 17.19 25.79 34.39 42.99 51.58 3rd 26.05 39.08 52.10 65.13 78.16 4th 34.39 51.58 68.78 85.97 103.17 5th 50.57 75.86 101.14 126.43 151.71
#25
RE: 4:10 or 3:73s'?
ORIGINAL: jbailer
Although now I have to admit I'm even considering 4.30. I won't be using it as a daily driver but I still want it to drive nice on the road so I'll probably go 4.10 when I ever get my car. I'm so jealous when I see cars like RICVA05's, man that looks nice! -Joe
I would thank twice about getting 4:30's if you do much highway driving RPM'S will make you feel like you need a 6th gear. Thank you for the compliment
[quote]ORIGINAL: 757 GT
I didn't know yours was auto, I was thinking manual for some reason. I probably should have gone with a shorter gear but I had never had 3.73s so I though I would try them out.
Maybe when Richmond opens back up in the spring we should go show them what the 05 's can do.
#27
RE: 4:10 or 3:73s'?
ORIGINAL: chevykiller
Ditto to RICVA05
I have 4.10's and run about 3200 rpm at 75 mph. Not the best for highway driving. You would definitely want that elusive 6th gear with 4.30's.
Ditto to RICVA05
ok 1.) gears do not kill your gas milage it is your right foot, 2.) higher rpms are fine for the engine and there is only a few hundred between 3.73, 4.10, and 4.30,
heres a general rule, foxes should go with 3.73s, SN-95s should go with 4.10s, 05s go with either 4.10s or 4.30s.
#28
RE: 4:10 or 3:73s'?
Gears won't hurt your mileage? How is that possible. If you have to turn the motor more revolutions to go the same distance on the freeway how do you not burn more gas with the extra revolutions?
#29
RE: 4:10 or 3:73s'?
ORIGINAL: mustangman02232
and you know this because you have 4.30s in your car right?
Ditto to RICVA05
Ditto to RICVA05
I have 4:10's in my car and I know what the engine sounds like at 70 MPH with 4:10's I could not imagine what the RPM'S would sound like with 4:30's at higher speeds. If any body want's to get them they should find somebody who already has them installed on a 05 or 06 before taking the plunge.
#30
RE: 4:10 or 3:73s'?
ORIGINAL: RICVA05
Ditto to RICVA05
Ditto to RICVA05
