Strange tranny/clutch noise during shifts
RE: Strange tranny/clutch noise during shifts
Is this relative to the actual tranny, or the shifter? Obviously my S281 has a short throw adapter from Saleen, and I don't have any clunking noises. Just wonder if adding the Saleen quick ratio adapter (only $29) or even upgrading to a Tri-Axe (the word axe is so cool ) or some other shifter would eliminate these "clunks"??
the clunk i'm referring to has nothing to do with shifting- its backlash sound as engine goes from 'powering to braking' as you lift throttle after accelerating, or when releasing clutch at downshift...the little bit of rotational slop in the gearbox/slipyoke splines causes a slight 'klunk' as its taken up in the other direction...I think a lot of this could be the ATF used in manual gearboxes now too- older boxes ran heavy oil, and although it robbed power, it has a bit more damping to it...although my 93 f150 had ATF too and the 5 speed in it was quiet except for a bit of synchro whine at downshifting(normal).
Something odd- anyone know why ford chose to use a ujoint front/cv joint center&rear setup? kinda defeats the purpose of the cv joint dont it? unless the cardan u-joint is paired with 2nd there will be slight velocity changes between input/output shaft...seems a cheeper one piece driveshaft woulda made more sense and cost less to boot...with 2 ujoints the shaft velocity will fluctuate but input/output wont as long as angles are equal...or better yet 2 cv joints to make it all smooth...I did rotate driveshaft with a finger in it and you can feel gaps open close, so ujoint does have a bit of angle to carrier bearing...
Welcome to the wonderful world of mustang transmissions. It is noisy turn the radio up and get over it why are you shifting at low rpm's anyway?? DRIVE THE CAR!!!!
[/align]
KingRando
10-02-2015 08:06 AM
