Handling Performance Any questions about suspension, steering, tires, or rims can be asked here!
Sway bar swap?
Old Aug 16, 2012 | 08:58 PM
2008Vert's Avatar
2008Vert
Default Sway bar swap?
Will the front and rear sway bars from a 2008 vert fit a 2013?
Old Aug 17, 2012 | 12:56 AM
Red_Devil's Avatar
Red_Devil
Official Sponsor For Whiteline USA
The front bushings and mounts are different
Old Aug 17, 2012 | 07:10 AM
2008Vert's Avatar
2008Vert
So the rear would fit but the front would not?
Old Aug 17, 2012 | 09:03 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Why are you looking to change the sway bars?
Old Aug 17, 2012 | 10:19 AM
2008Vert's Avatar
2008Vert
I am considering selling my 08 for a 13 .
Old Aug 17, 2012 | 11:16 AM
Jazzer The Cat
Retired Moderator
Soo..... you want to remove the bar from your car and sell it without one to the new owner? Or... did you buy an aftermarket one you want to remove for the '13 and going to re-install the OEM one to sell the '08?
If so, you may/may not need a front sway bar on your new car. It should be pretty well balanced and even have bit of understeer. In such a case, a heavier front bar would make such a condition worse, so drive it for a while first and see how she does in da corners
Jazzer
Old Aug 17, 2012 | 01:04 PM
2008Vert's Avatar
2008Vert
Well, not exactly. The 2008 base v6 did not have a rear bar from the factory so I was just going to remove the Eibach bars I bought and put the original front bar back on. This would put it back to factory specs. Which the dealer has told me (trade-in) he would rather have the stock setup anyway.
If the new one doesn't need it then I would sell the bars I have here.
Old Aug 17, 2012 | 07:12 PM
Jazzer The Cat
Retired Moderator
If you are buying a '13 GT, it will already have both bars. If not, I would think they should fit, but don't have enough knowledge to say for sure. I am going to forward this thread over to the S197 Handling Performance section and them pepes will know.
Jazzer
flash_xx
Oct 16, 2015 07:23 AM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
