Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Mach 1 + Cobra Engine?
Old Jul 21, 2007 | 08:27 AM
RAT's Avatar
RAT
Default RE: Mach 1 + Cobra Engine?
ORIGINAL: St4ng07
Also the mach does not have the forged internals nor the same compression ratio, the mach has the same engine as a mercury maruader.
The crank is different in the5-speedMach 1 (8 bolt Forged). Maruader has a cast crank like the auto Mach 1.
There's also the al block in the Mach vs a cast iron blockin the 03-04 Cobra. I have word from a few Parts guys at Ford the part numbers on the Mach cams and the 03-04 Cobra cams are the same.
Old Jul 22, 2007 | 08:47 PM
QatarStang's Avatar
QatarStang
ORIGINAL: 04SuperMach1
The 03 & 04 Mach 1's did not come with the 5.4Lt because of the size of the engine compartment, but the 4.6Lt is stock for the Mach 1and it is the same motor as the cobra with just two main differences. The first is the Supercharger for the Cobra model versus the naturally asprated Mach 1. The second is the Camshafts where different in both engines. The Mach 1 had better lift and durantion on the Cam shaft versus the Cobra model. What some people are doing is putting the Mach 1 version camshafts in there Cobra's to give them more horse power. I hope that help you in answering your question for the 5.4 Lt and the 4.6lt cobra/mach1 motor.
No. You have one post, and its wrong information. Not a strong start.
The guy who said it has the same engine as a marauder was the closest, as the only real difference are a couple forged pieces in the mach versus cast in the marauder. Both the mach and the marauder use heads from the 5.4 used in the navigator.
Nick Oliver
Oct 17, 2018 04:22 AM
Nov 10, 2015 11:39 AM
Sep 8, 2015 06:25 PM
iamgobono
Sep 3, 2015 12:37 PM
Sep 1, 2015 08:16 PM
