Underdrive Pulley's
Has anyone used under drive pulley's on their Mach? I have a set of Steeda pulleys on my Mach and I had someone tell me that under drive pulley's can cause oil pump failures on the Mach's 4V motor. They have been onthe carfora while and no problems so far, has anyone ever heard this? The steeda pulley's aren't a cheap piggy pulley like the others and have a balancer built in with the crankshaft pulleyto Ford Spec's. Do I need to that this into concideration?
Ricky
Ricky
You might be one of the lucky ones but yes... over on the mach1registry... everyone fears them and decides to save a $100 or 2 and spare some horsepower elsewhere. IMO I'd stay away from them.
Im still trying to figure out how a pulley can cause an oil pump failure? I know that the oil pump is driven off of the crank shaft but wouldn't a underdrive pulley make less stress on the pump it self as well as the crankshaft?
Read here:
DO NOT PUT UDPs ON YOUR MACH
ARE UDPs GOOD OR BAD FOR THE CAR?
STEEDA UDPs
Give you a bried summary of why we hate them lol
STEEDA UDPs
ORIGINAL: Slicktastyk Matt
Read here:
STEEDA UDPs
Read here:
STEEDA UDPs
Ricky
[sm=funnypostabove.gif]
You asked the question first in your post, so you must have had some reservations about using them. If, as you stated, most of what you read on the internet is BS, why then did you post your question on an internet forum?
ORIGINAL: Baron von Munchausen
I was also looking for a more positive feed on the subject, most things brought up on forums have more negativity these days. I tend not to browse as much as I used to, but Im still learning, the Mach I own has only been sitting in my garage for three weeks now.
I've got em, and I have no issues - I was the same way, I was asking in all sorts of forums, worried about the pump, I called Steeda, Ford, and a bunch of local speed shops, all of them said the same thing:
"The underdrive pulley's did not cause the catastrophic failure, drivers bouncing off or removing the rev limiter and then staying in the red zone constantly broke the oil pumps."
