Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Springs
Old Oct 29, 2007 | 10:02 AM
ben790450's Avatar
ben790450
I ♥ Acer
Default Springs
I put stock 04 Mach one springs in my stang. After trying all kinds of different springs they seem to be my mama bear. They seem to be the perfect balance of good weight transfer and handling. Not too stiff not too soft. Not too low not too high.
Does anyone know the spring rates on these? The rears look about the same as stock GT springs but the fronts look much stiffer and larger. . .
Old Oct 29, 2007 | 01:33 PM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Springs
The Mach's front rate is 600 lb/in and the rear is 250 lb/in.
The GT's front is 450 lb/in and the rear is 210 lb/in.
Old Oct 29, 2007 | 01:57 PM
ben790450's Avatar
ben790450
I ♥ Acer
Default RE: Springs
Ah so the rears are a little stiffer. Thank you very much!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
