Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Mach 1 with a vortech???
Old Dec 2, 2007 | 12:34 PM
Stone629's Avatar
Stone629
Default RE: Mach 1 with a vortech???
He won't. I don't have nearly as much power as him and my 4.10s spin my tires for days. He should drop back to 3.55s or get some suspension work and tires.
Old Dec 4, 2007 | 02:13 PM
kx714's Avatar
kx714
I've got a Vortech w\intercooler and with a very conservative tune it's getting 467 rwhp on the dyno. At the strip I've had issue with the trans, but still I'm turning 12.35 @ 122 mph. I'm installing 4:30 gears now, as the 3:55's don't get it off the line very well, even with drag radials. I gotta disagree with Stone, the higher the numerical gearratio the better offf the line. With my 3:55's I can smoke 315/25/19 Conti's just by flooring it in 3rd gear at 55 mph.
Old Dec 5, 2007 | 12:20 AM
Stone629's Avatar
Stone629
The higher the numerical number of the gear the faster you get into your powerband reducing traction in most cases. Those 315 Conti's are no match for your car with that kind of power. It is extremly difficult to take full advantage of low gears (high numerical) without control arms and DRs. If those 3.55s get loose in third or suck on DRs at the track, then the 4.30s are going to break loose even worse. 4.10s are way better off the line if you are set-up properly for them, otherwise, you'll just end up pedaling/feathering it that much more. With 4.30s and a supercharger, you'll be changing gears like a semi. I'd love to see a Mach 1 with 4.30s do a 4k rpm launch at 9psi on slicks though!
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
