Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
mach 1 internals
Old Jan 6, 2008 | 12:53 PM
rd50stang's Avatar
rd50stang
Default mach 1 internals
Do mach 1's have forged internals??
Old Jan 6, 2008 | 01:28 PM
Stone629's Avatar
Stone629
Default RE: mach 1 internals
Only the crank is forged, and that's only with the 5spd. The autos don't have a forged crank. Everything else is cast.
Old Jan 6, 2008 | 07:20 PM
nikbait's Avatar
nikbait
Yep, what he said.
Old Jan 7, 2008 | 04:04 AM
jmac72187's Avatar
jmac72187
corner carver
Mach's have the same limit as a GT. The forged crank doesn't up it. I think that the rods are the weakest point.
Old Jan 7, 2008 | 07:33 PM
pandaj's Avatar
pandaj
what are usually the first things to fail on a mach?
ive heard the control arms in the rear or the tranny but what combination makes these things fail? ie certain hp or slicks and 4:30, i was thinking about 4:30's in the future
Old Jan 7, 2008 | 07:55 PM
Stone629's Avatar
Stone629
I know powershifting is causing my clutch to fail!! It's about 1/2 gone
I would say it's a combination of things that cause the torque arms to go, but mainly wheel hopping at the track,or DRs on heavy launches,and the fact that the lowers are some of the most pathetic looking littlecontrol arms I've ever seen. The connecting rods are most likely not going to break unless you are pushing boost, or a big shot of gas. I would be more concerned with the transmission rather than the Motor since it's really what takes the beating at teh track.
You will need LCA's if you get gears. Since I did 4.10s, I my tires are hopping bad at the track.
Old Jan 26, 2008 | 06:04 PM
Fuel's Avatar
Fuel
machs don't have irs though do they
Old Jan 26, 2008 | 08:43 PM
HamMach1's Avatar
HamMach1
No they do not, sir!
Solid rear [8D]
Old Jan 26, 2008 | 10:49 PM
Fuel's Avatar
Fuel
well that is good to hear
Old Jan 27, 2008 | 10:48 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
mach limits are the internals are 450-500rwhp at most, same as the 99-01 cobra better get your tune str8
