Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
MACH 1 S/C question
Old Jan 21, 2008 | 10:29 PM
MACH1_370's Avatar
MACH1_370
Default MACH 1 S/C question
What else is need for an Eaton M112 installation
-M112 Eaton Supercharger withStock Pulley
-Throttle Body and Plenum
-90mm Mass Air Flow Sensor (MAF)
-39 lb.Fuel Injectors
-Heat Exchanger (Intercooler)
Old Jan 22, 2008 | 05:45 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: MACH 1 S/C question
I think it would be too much of a hassle to put a crappy blower on.
Old Jan 22, 2008 | 07:58 AM
Furinox's Avatar
Furinox
theres a parts list a mile long on the mach1registry website.
Old Jan 22, 2008 | 08:44 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
ORIGINAL: jmac72187
+1000
just slap a KB on or a P1cs/D1sc much better results and easier to work with on any of those.
Old Jan 22, 2008 | 01:23 PM
5speedstang's Avatar
5speedstang
your going to need to swap around everything on the front of our motor for it. the altinator needs to be in the lower left side of the motor. its just too much work.
Old Jan 22, 2008 | 02:29 PM
HamMach1's Avatar
HamMach1
I think this is the list you were referring too
(6312) Crank pulley /Harmonic Balancer
(6312B) Supercharger Crank drive pulley
(8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s
(6B209B) Pulley bridge assembly for S.C.
(8678B) Idler pulley,timing cover LH side
(6D080) Timing cover
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
(8260) Radiator hose
(8A593) Radiator hose
(8K576) Radiator hose
(8548) Water cross over pipe
(6881) Cobra oil cooler adapter
Note: Use your stock gasket from your adapter or a leak will occur
with a Cobra gasket!
(6A642) Cobra Oil cooler
(9002) Cobra fuel tank
(9H307) Cobra fuel pump
(6F066) Eaton supercharger
(9424) Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-JUA IAT sensor connector
(9H308A) Intercooler hard lines that hug the block
(9N491A) Intercooler hard lines that come from the h/e
(9L443A) Intercooler pipe to heat Exchanger that goes from the i/c adapter to i/c res.
(9L443B) Intercooler pipe to heat Exchanger that goes from the i/c adapter to the hard lines that hug the block
(9L443C) Intercooler pipe to heat Exchanger that goes from the hard line to i/c pump
(9L443D) Intercooler pipe to heat Exchanger that goes from hard line to hard line coming from h/e
(9L443E) Intercooler pipe to heat Exchanger that goes from hard line from h/e to i/c pump
(9L443F) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(9L443G) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(8501) Ford / Bosche water pump for intercooler
(8K226) Factory heat exchanger
(8A193) Heat exchanger mounting bracket
(8C386) 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
(9A589) Plenum
DELETED TB SAME AS MACH
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
(9F593) Injectors
(6F089) Boost bypass actuator
(8N500) Intercooler pump bracket
(9A825) Cruise control cable
(9A758) Throttle cable
(9728) Throttle and cruise control cable mounting bracket
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
(9F670) IAC gasket
(6020) Timing cover gasket LH side
(6020) Timing cover gasket middle
(6020) Timing cover gasket RH side
(9H486) Intercooler to S.C. gasket
(9L437) Plenum to S/C gasket
(9D476) EGR gasket
Old Jan 22, 2008 | 03:25 PM
jmac72187's Avatar
jmac72187
corner carver
Haha... have fun.
Old Jan 22, 2008 | 04:29 PM
03_svt_cobra_22's Avatar
03_svt_cobra_22
ORIGINAL: Slicktastyk Matt
(10346) Alternator
(9424) Lower intake
(9A589) Plenum
(9F715) IAC valve
(9F593) Injectors
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F670) IAC gasket
(9D476) EGR gasket
dear lord in heaven![]
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
