Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
mach 1 upgrade???
Old Feb 10, 2008 | 05:16 PM
newbie101's Avatar
newbie101
Default mach 1 upgrade???
I want to add some more ponies to my 03' mach 1. Its stock now I was thinking heads,cam,full exhuast,gears, what do you think I am looking for any help on how to built it. please email me tkhoury@cmaaccess.com
Old Feb 10, 2008 | 06:18 PM
jmac72187's Avatar
jmac72187
corner carver
Default RE: mach 1 upgrade???
How much HP you want? Heads and Cams are going to be expensive especially on a 4v because of the DOHC. Full exhaust, intake, intake spacer and tune should put you above 310rwhp. You could spray or go for Forced induction such as turbo's or a supercharger.
Old Feb 11, 2008 | 11:10 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
what's your budget?
Old Feb 11, 2008 | 05:28 PM
newbie101's Avatar
newbie101
I was thinking budget around $7K, I may just add all the bolt on I can the just add a supercharger to it. I really aint sure on what route I want to go
Old Feb 11, 2008 | 07:27 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
if you got 7k you got lots of options.
here's what i'd do
3/8" intake spacer
aluminum DS
3.73 gears
total so far like 700
Next
i would get a forged shortblock 2-3k
then put a KB 2.1 with the 7-9lbs of boost
the buy a 12psi pully cheap swap it then tune it, you'll like that one.
Old Feb 12, 2008 | 02:53 PM
5speedstang's Avatar
5speedstang
first off if you go with the kb you sure dont need the spacer. if you go with a spacer which roys are amazing. i would go with 7/8ths and delete the egr. 4.10 gears nothing lower in the machs bc they come with the 3.55. and for power the kb is nice bc is sits under the shaker, an she sure screams.
Old Mar 5, 2008 | 12:45 AM
rygi23's Avatar
rygi23
forge the internals, install turbo, full exhaust, and gears. not sure if the 7k will cover the exhaust and gears.
Damn, and I have gears I bought I can't afford to install and I'm struggling to buy a damn o/r Xpipe.
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
