Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Tranny Fluid
Old Mar 11, 2008 | 06:45 PM
jmac72187's Avatar
jmac72187
corner carver
Default Tranny Fluid
I bought an MGW a few days ago and I will be installing it sometime this week. I figured that I might as well change out the tranny fluid while I have the shifter off.
What type of fluid should I use?
I have heard Dexron III or ATF, but aren't those auto tranny fluids?
I also saw Mobil 1 ATF that said Dexron III on it. I am so confused...
Old Mar 12, 2008 | 07:10 AM
Machmax777's Avatar
Machmax777
Default RE: Tranny Fluid
yes our cars take atf. RP doesmakes something specialy for the tremec's i think though. I used RP atf, smoothed everything out alot.
Old Mar 12, 2008 | 11:24 AM
jmac72187's Avatar
jmac72187
corner carver
Weird but I guess I wil be using that. On cold starts, the first shift into second is hard to get in sometimes. I figured putting in the lower amount (3.2 Liters) would help out a bit.
Old Mar 12, 2008 | 11:51 AM
MACHJUAN's Avatar
MACHJUAN
RP atf= Royal purple?
Old Mar 12, 2008 | 12:02 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: redv6pony
Yup
Old Mar 12, 2008 | 12:22 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
tranny fliiud is some $$$$
Old Mar 12, 2008 | 02:36 PM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
RP or Synchromesh synthetic
Old Mar 12, 2008 | 02:51 PM
nikbait's Avatar
nikbait
Will lowering the fluid level and changing it to something different help with a 1-2 gear shift issue?
Old Mar 12, 2008 | 04:20 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: nikbait
Yup.
Old Mar 12, 2008 | 04:43 PM
clarehills's Avatar
clarehills
I used to have a 2003 GT (has the same tranny as the mach1) and remember seeing threads about a Tremec 3650 TSB about using less fluid (3qts instead of 4qts) to prevent stress on the gears (it was described as trying to run through knee high water if that makes sense). Anyway, here is a link to a page where someone talks about this issue at length:
http://www.bullittarchive.com/1023.htm
I tried to find a link to the actual TSB but couldn't find it. Hope that helps.
