Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
air resonator plug...
Old Apr 29, 2008 | 11:16 AM
renegadeoffunk0's Avatar
renegadeoffunk0
Default air resonator plug...
I took out the "milk jug" and plugged it with a rubber stopper (2-1/4" x 1 3/4" x 1") and had to take off the clamp that was originally around where the tube meets the silencer. The plug is snug enough but I have a question as to whether or not I need to help reinforce it in any way. I was thinking either a hose clamp or a good ol' zip tie but is it even necessary?
thanks
Old Apr 29, 2008 | 12:33 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: air resonator plug...
there should be the (2?) plugs on the bottom, and a screw that helps keep the filter and coffe can in place.
Old Apr 29, 2008 | 01:20 PM
meechuacon's Avatar
meechuacon
I've got an 03, and it is already plugged. I was wondering what that "milk jug" does?
Old Apr 29, 2008 | 01:21 PM
renegadeoffunk0
I'm not talking about the filter box. It's on the intake after the MAF
http://mach1registry.org/forums/atta...p;d=1182995527
the circled thing was removed and the remaining hole was plugged with a rubber stopper.
I believe it's a noise dampener of some sort. More like a storage unit for hot air when sitting still...
Old Apr 29, 2008 | 01:54 PM
USMCrebel's Avatar
USMCrebel
HUH, i will be looking at mine this afternoon.
Old Apr 29, 2008 | 02:29 PM
meechuacon's Avatar
meechuacon
Yeah, mine was already plugged. I thought only 04's had that jug on there.
Old Apr 29, 2008 | 05:56 PM
B.O.B MACH 1's Avatar
B.O.B MACH 1
ORIGINAL: renegadeoffunk0
thanks
I did the air silencer mods on my old intake set up. I used a home depot rubber stoper. Then i used a hose clamp so it wouldnt fall off, and it would seal better. I dont think you need to use a clamp, mine was snug with out it. I just used mine to make sure i didnt lose the plug one day while i was driving.
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
