brakes and shaker
brakes and shaker
i am about to change my brakes and probably get the rotors turned for right now until i can get some new ones. what is a good, but not too expensive brake pad for the mach? i found a kit that moves the shaker up higher into the air stream, how much if any of a hp difference will that make?
RE: brakes and shaker
Hawk HPS brake pads are great upgrade, as for the shaker what are you explaining to us?
Is it the Shaker Air diverter or a simple shaker raise with the washers? or is it the 1 inch extension?
The best way would be to put on a intake spacer. As far as turning rotors I personally would buy new, turning them would give you a new finish to burnish the new pads but at the risk of warping the rotors. Plus the money you wasted on turning them could of went to new rotors my 2 cents.
on the brakes, im clueless i havent done in research into them.
BUT for the shaker, moving it up will just move a slightly more amount of air into your engine. you wont see any noticable gains worth buying the kit...btw you dont need a kit to do it.
+1 for the hawk hps. I got them on my car with brembo drilled and slotted rotors. The car stops alot better then stock. Everything only costed $445. $165 for pads $280 for rotors, that included shipping.
intake spacer is 100 from RoyC, but if you dont want to pay there is a link i can get you to show you how to raise it.
what about some carbon fiber brake pads anyone got exp with anything like that?
